Driving this afternoon I noticed that the shift pattern seems to have changed. That's the best way I can describe the symptom.
1st seems to feel almost where 3rd was, 2nd feels a tab to the right and so on. Even to the point where shifting into 3rd I actually put it back into 1st which i have NEVER done in 15 years. All the subsequent gears are there, 3rd, 4th and 5th. However after 1st and second seem to have moved to the right in the shift pattern 3rd and 4th are very finicky to find and very close to 1 and 2. Does this sound like busing, coupler, etc issues? Or something else potentially? BTW I do already have a WEVO Shifter. Thoughts? Thanks!
Past: 04 Anniversary 911 #0895, 82 911 SC, 88 Signature Series Carrera, 88 911 Turbo Cab, 73 911T, 63 356B, 06 Cayenne |
Simple enough to pull the rear tunnel cover and check busing coupler... that's where I'd start.
Sounds like the clamp on the coupler/rod has worked loose.
RGruppe #180 So many cars.. so little time!! |
Under the radar
Most likely the coupler bushings have self destructed. Very common. Should check the other bushings under the shifter while in there.
That.
RSA Pinky Helga Turtle Carrera Luigi CDtdi |
Thanks for the direction. Glad that I found this to be the cause. A quick search and found this and more inside the rubber boot.
Is this bad ![]()
It looks like you should replace all your bushings at the gearlever and the coupler. These jobs are straightforward if a little fiddly. There are instructions how to do these in the Technical section and plenty of threads where people have had similar problems to you. I did this job on my car although I didn't find catastrophic failure I did find 'tiredness' and updating the bushes took away vagueness.
The parts are not expensive but make sure you change all of them to be sure... I hope that is helpful. Cheers, Neil |
You still need to check your coupling in the rear to ensure that you get it all.
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
bushing.
![]() ^^^^^ Yup-Here's was mine............................ also, as per the previous post, replace the shifter bushings. Good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 05-04-2015 at 03:11 PM.. |
Thank you all. I've ordered new bushings for the coupler and under the shifter from our host. They'll be here Friday. Just in time for another weekend project.
Coupler Whisperer.....or Wevo or Rennshift....
Scott "Houston, Tranquility Base here, the Eagle has landed" Silver 1984 M491 Sunroof Coupe |
Member 911 Anonymous
Keep us posted
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Removed the bushings. Here are the results. The one's below the shifter look decent, however I'm still replacing them.
