Schleprock
Like LJ851 said, you can't "reverse offset" the standard hubs to space them out. The later 930 hubs are extended by how the hub is cast. Basically it has a longer "stem" on the back side of the hub to push it out further. Here's a picture of a standard hub (right) next to a 930 extended hub (left).
![]() Get some Rebel hats, good high strength fasteners of the proper grip length and use Wilwood 11.75 x 1.25 rotors that have 8 x 7.00" bolt circle mounting. That's a cheap, proven solution. This rotor fits the Rebel hat perfectly and is plenty sufficient for street use, since I believe Scott (winders) uses this rotor on his GT-L racecar Wilwood High-Performance Disc Brakes - Rotor No: 160-2898 Or if you want a more robust disc because you want to spend more money on slots or hooks, use the Wilwood GT disc or an AP Racing disc. Wilwood High-Performance Disc Brakes - Rotor No: 160-11837 Essex - AP Racing J Hook Don't get me wrong, I know the GT or AP disc is more than just slots and hooks on their faces. But for street use they are way overkill and just wasting money IMO AP also has a nice hardware kit that is reasonably priced. http://www.essexparts.com/shop/brake-discs/competition-disc-hardware/disc-attachment-hardware-kit.html
Kevin L '86 Carrera "Larry" |
HERE IS A PIC ON HOW I HAVE BEEN RUNNING FOR PAST 20 YEARS. I HAVE THE 1" SPACERS ALREADY.
You have an '84 Carrera 3.2 w/ widebody 930 fenders w/ that combo the later '81 up 930 rotors bolt up to the stock 911 hubs just fine and the 930 front calipers bolt to the 911 struts. you will want to use 930 rear calipers and rotors too, whether these bolt on depends on the trailing arms you have, if you have 911 arms w/ leading caliper position then the rear 930 caliper need to be modified to fit the 3" 911 leading mounts, if you have 930 trailing arms w/ trailing caliper position then the 930 calipers and rotors will bolt on w/o issue. You will also want to use a 23.8mm boosted 930 master cylinder, these wer used on al 930 from '78up
Schleprock
Bill,
With all due respect I think you're forgetting that w/out using the '81-up 930 front hubs, the deep offset bell of the '81-up 930 rotor will not clear the A-arm/ball joint.
I do have the 930 rears. Have to send out to be modified to fit carrera trailing arms. Already ordered 23mm m/c.
Racer
...or line up properly with the caliper even if it did.
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
my bad, yes you will need the '81 up 930 hubs w/ the '81 up 930 rotors
You have spacers that move the position on the wheel, you need to move the position of the brake disc. |
here is a '81 up 930 front assembly, the caliper bolts to the strut in the same place for either narrow or wide fenders, the late 930 and '78-80 930 rotor is positioned in the same place in the caliper jaws, the late 930 hub/rotor assembly positions the wheel the same 21mm further out as the '78-80 911 hub/w/ rotor and flat hat. ![]() ![]() here is the 911 hub w/ '78-80 floating rotor and flat hat and 21mm spacer
I t looks like the carrera dust shield interferes with 930 caliper going on. Do i need to change to 930 also?
Ya, I didn't even bother with them on mine.
I have seen lots of people leave off for better cooling.
930 front wheel hubs
WAITING FOR 930 HUBS TODAY TO ARRIVE. CANT WAIT TO INSTALL FRONT BRAKES TODAY.
Hey guys thanks for all the help with front upgrade.Still need hub dust covers if anyone has laying around.
