LinkBack Thread Tools Rating: Thread Rating: 3 votes, 3.67 average.
83 911 Production Cab #10
JJ 911SC's Avatar
Originally Posted by pmax View Post
I was wondering if this means anything more than just a voltage monitor... It protects the engine computer and 12-volt accessories from damaging surges when jump starting or recharging."
I think they had a Brian Williams moment
Who Will Live... Will See
Old 06-19-2015, 03:12 PM
Burnin' Rubber
Koizumi's Avatar
Originally Posted by Neel View Post
Very nice!!! Where did you pick up the parts?? Good luck with your troubleshooting!!!
I got the parts on eBay from a couple of different sellers. The parts are all well-made, sturdy not flimsy at all. It's hard to capture with my iPhone but the install looks OEM.
Ebay Sellers:
Andy14nq
offroadarsenal
Inexpensive, too! I installed a 15A inline fuse as well. Took 15 minutes tops to install.
Old 06-19-2015, 06:14 PM
wayner's Avatar
Originally Posted by jclotz View Post
I had a gage made from a clock core by BigMarkDesign a number of years ago. Happy with the way it turned out.
I love the setup. Its perfect!
I've already got the spare gauge to work with. I talked to Harmut at Palo Alto, and he wasn't able to take on this project. I'll contact http://www.newvintageusa.com/bigmarkdesign.html
For now I'll attach a multi-meter for my next road trip. I always like to bring one along in my tool kit anyway.
SOLD - 914 wide body hot rod
Old 08-28-2015, 04:09 AM
wayner's Avatar
Darn. They just got back to me to let me know they no longer work on our gauges
Old 08-28-2015, 09:30 AM
I went down the same road and contacted Palo Alto and Mark with no luck. The difficulty is in the AFR movement. I'm pretty close to having a working gauge. I worked with an electrical engineer to design an external box that will drive the 2 stock fuel and oil level movements. This way, no modifications need to be made the the stock gauge other than the faces. It's also nice because the needles both move from top to bottom like the stock gauge. The electrical work is done and I'm having the faces made now. I'll post some pictures when everything is done. Should be a couple weeks.
1970 911E Sportomatic Albert Blue
1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI
1973 911E Glacier Blue
1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI
Old 08-28-2015, 09:38 AM
wayner's Avatar
I have a donor fuel gauge
Any ecomonies of scale here if I piggy back on your project contributing to your cost recovery?
Old 08-28-2015, 10:37 AM
scarceller's Avatar
Great addition for our cars CHT and VDC the other would be a Fuel Mixture gauge.
yep, there it is....too lazy to look or take another pic. Like $40 bucks.....
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 08-28-2015, 10:53 AM
Always Be Fixing Cars
Lots of cool solutions here. Anyone find a cigg lighter option that is a bit more.... 80's looking?
Also wondering what the alternator idiot light reports? Total failure (ie belt snaps) under charge? Over charge?
'91 964 C4 - New Daily
'73 Alfa GTV - 90% done 50% to go
'65 912 - Welding in process
Old 08-28-2015, 01:28 PM
All the heavy lifting is done... I'll post pics as soon as it's done. I'll post some pics showing what I did and I'll see if we can make the parts available. I have no interest in building these or making money on it so I'll do what I can to pass it on.
Old 08-28-2015, 03:37 PM
wayner's Avatar
Thanks!
Standing by
Old 08-28-2015, 04:44 PM
MrScott's Avatar
I ordered this warning light off eBay. It has different warning colors depending on condition (low battery, over voltage, etc.)
I was planning to run it in mode 4 (below), maybe install it in the unused warning slot in my oil pressure gauge or on the dash where the OXYs light is. I still haven't received it so it could turn out to be junk. If not I'll do a write up and post it. Mentioning it now because it seems relevant.
1980 911SC
Old 08-28-2015, 06:04 PM
KTL KTL is online now
Schleprock
KTL's Avatar
Here's some good information on the alternator light function. It's more than just a typical light bulb being turned on!
Race Car Dash Alternator Light
Kevin L
'86 Carrera "Larry"
Old 08-31-2015, 10:09 AM
Thanks!
Standing by
Here is a picture of the finished gauge. As I mentioned it is a standard fuel/oil level gauge with new gauge faces. The little box converts the voltage and O2 sensor signals to the correct voltage ranges for the stock gauge movements. This setup works with the older narrow band sensor.
Old 09-14-2015, 09:11 PM
wayner's Avatar
Can I order an electronic box from your guy?...or a kit with schematic??? Pre-assembled would be great.
Where can I get the gauge refaced?
Looks like the prefect solution (other than narrowband, but I can live with that ;-)
Old 09-15-2015, 08:20 AM
Let me talk to him and see if he'd be interested in making more of them. This is a one off board that he made for me so it wasn't too cheap. Then there are the faces. Those weren't cheap either since I had to have the artwork done and have the overlays made. The 2 small faces are overlays. The main gauge face is another story. Palo Alto and North Hollywood wanted more than $500 to re-screen that face and I couldn't find anyone else that would do it because it's not flat. So I bead blasted and painted a face and used dry rub lettering myself. Then a coat of matt clear over top. I'll let you know on the box and I can check with the guy that printed the overlays to see what it would cost for more. Sorry it's not a more simple answer.
I too wish there was a way to use a wide-band sensor but the circuitry is much more complicated and we couldn't come up with a way to use the existing movements. For one of my other cars I'm putting together a wide-band gauge using the parts from a clock but it will be a full sweep gauge based on the innovate gauge (no volt meter). I'll post a picture of that in a couple days.
Old 09-15-2015, 03:49 PM
My other ride is a C-130J
RNajarian's Avatar
Great advice Wayner, you motivated me to get some "insurance" as well.
My car has the dealer installed air conditioning unit installed. So I was able to buy a VDO bracket which fit perfectly in the space of the never used ash tray.
I installed an OEM 55 mm VDO voltmeter and an OEM VDO 55mm outside temperature gauge
Doesn't look too bad. I love knowing the status of my electrical system
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic
2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 11-02-2015, 08:01 AM
gliding_serpent's Avatar
My battery gave up the ghost mid lap at a hpde. I lost all power and the hood was smoking a bit, but i was "lucky" and there was no leaking. I have since switched to agm batteries, and saved some weight in the process.
1997 BMW M3 (race car) with S54 engine swap "The Rocket"
1984 Porsche 911 3.4 Carrera
1973 BMW 2002Tii
2016 Ford Focus RS
Old 11-02-2015, 08:09 AM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
The battery was just the symptom. AGM will not save you from an overcharging problem, it will just delay the inevitable, with bigger thrills. Do some diagnostics, STAT!
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 11-02-2015, 11:14 AM
wayner's Avatar
Originally Posted by ClickClickBoom View Post
The battery was just the symptom. AGM will not save you from an overchatprging problem, it will just delay the inevitable, with bigger thrills. Do some diagnostics, STAT!
Ditto
This WAS an AGM battery. AGM won't save you from a battery explosion if you are overcharging.
RUN! She's gonna blow!!
Old 11-02-2015, 04:35 PM
wayner's Avatar
Thats was easy!
(I still haven't gotten around to following my own advice but I did ride with a multimeter on the passenger seat last outing).
Old 11-02-2015, 04:41 PM
