LinkBack Thread Tools Rating: Thread Rating: 3 votes, 3.67 average.
Scott S's Avatar
I wish there was a volt meter that replaced the clock that was not a retro fit - a gage that was truly the right size and matched the other stock instruments. I may give NHS a call and see what the damage would be to create one using my clock housing.
Anyone ever done this?
- A pile of British stuff
- A growing pile of German stuff
... oh, and two Hondas - complete with car seats and pounds of fish crackers smashed into the carpet (and seats, and door pockets, etc etc etc....)
Old 05-22-2015, 08:26 AM
RETIRED
Joe Bob's Avatar
Yup.....I did, years ago. I had Wesstach make me one. 1/3 the cost from NH Speedo. Does it match? Nope but close enuff.
2012 ML350 3.0 Turbo Diesel
Old 05-22-2015, 08:43 AM
Vintage Owner
Jack Stands's Avatar
There's the one I got from Amazon. Usually reads 14 volts after starting and then runs at ~13.5 volts while driving. Cheap and easy to read.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 05-22-2015, 01:01 PM
I had a gage made from a clock core by BigMarkDesign a number of years ago. Happy with the way it turned out.
'72 911T
'73 MGB (sold)
'71 Alfa GTV (sold)
Old 05-22-2015, 01:17 PM
Information Junky
island911's Avatar
It looks awesome. Show me pics of volt gage install
Old 05-22-2015, 04:14 PM
RETIRED
Joe Bob's Avatar
yep, there it is....too lazy to look or take another pic. Like $40 bucks.....
Old 05-22-2015, 04:19 PM
pictures
Here are pics of voltmeter in tach by N. Hollywood in my 70 and 88. Good info.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 05-23-2015, 04:29 AM
Venetian's Avatar
The Amazon digital mentioned above says it will not fit in 911 lighter. Based on comments I assume that it actually does ??
1987 Carrera, Venetian Blue.
Old 05-23-2015, 10:04 AM
Reiver
Reiver's Avatar
German lighters are a bit wider....there was another thread on fixing this elsewhere.
I use a lighter powered radar det. and that plug wouldn't work until I purchased a US replacement receptacle at my FLAPS for a few bucks and cut the back end off (1/2 in).
Then slide that into place (nice tight fit) and you can use any US device.
De Oppresso Liber
Strength and Honor 5th Legion
Old 05-23-2015, 10:19 AM
http://forums.pelicanparts.com/uploads24/image1432299708.jpg
this one fits in my 73.5 lighter just fine. I get 13.87v from my charging system. Probably a bit of voltage drop because I did not solder the wiring output crimps from the alternator. Will be on my to-do list next time I'm in that area.
RETIRED
Joe Bob's Avatar
911 cig ports are not the same as US ones. A charging port from Manny, Moe and Jack can be put into the circuit. IT will work with a plug in style volt meter. They just aren't that accurate or reliable.
Old 05-23-2015, 10:39 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Overvoltage is THE leading cause of Bosch CDI ignition box failures. It will burn up components and the PCB. Unfortunately, spikes are as bad as constant overvoltage.
I have seen dozens of boxes that failed that way, mostly 3-pin boxes. I guess the earlier regulators were less reliable and thus it's the 3-pin boxes up to '78 that get hit the hardest by this.
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 05-23-2015, 11:12 AM
That gauge looks great. What are you using as the sender for the fuel mixture gauge?
1970 911E Sportomatic Albert Blue
1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI
1973 911E Glacier Blue
1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI
Old 05-23-2015, 11:20 AM
Still here
pmax's Avatar
Originally Posted by JJ 911SC View Post
This one work very well and is accurate. Got it AFTER i boiled the battery...
Amazon.com: INNOVA 3721 Battery and Charging System Monitor: Automotive
Amazon comments are right. It's a loose fit. Not sure it will stay under 'spirited driving' conditions !
Not sure the LED's serve any purpose other than displaying voltage levels.
Old 06-19-2015, 09:52 AM
Burnin' Rubber
Koizumi's Avatar
DANGER! install volt meter now!!
Installed this neat and vital Voltmeter and also added a dual USB port with a cover (each port running 2.1A for fast charging). Looks OEM and functions great.
I believe my VR is starting to give up the ghost. I installed the voltmeter to audit fluctuations. I've got a car with flickering dash + headlights whilst not under load. Hmmmmmm, grounds, VR, alternator ...
Old 06-19-2015, 10:15 AM
Reiver
Reiver's Avatar
It is a great fit if you adjust your German off sized cigar lighter to US size.
Numerous posts on this.
Basically cut down (shorten) and insert a US cigar lighter receptacle in your German one...bang, works.
De Oppresso Liber
Old 06-19-2015, 10:28 AM
83 911 Production Cab #10
JJ 911SC's Avatar
Actually mine has the original size lighter and it has never came out.
The digitsLED only shows the voltage, not sure what else could be expecting from a $12 item.
The one on the edge show the charging state Red / Yellow / Green
Who Will Live... Will See
Old 06-19-2015, 02:06 PM
bugstrider's Avatar
I double this request.
Cheers
-Palpatine (Robot Chicken)
1978 911SC Targa
Working Projects: 1968 912
Old 06-19-2015, 02:25 PM
Very nice!!! Where did you pick up the parts?? Good luck with your troubleshooting!!!
70 911T Sold 81 911SC Coupe
84 Mustang Turbo GT
66 Galaxy 500 Ragtop (my Mother bought it new)
88 Thunderbird Turbo Coupe
69 Torino Cobra (R) Code
Old 06-19-2015, 02:38 PM
Still here
pmax's Avatar
I was wondering if this means anything more than just a voltage monitor.
"The INNOVA Battery and Charging System Monitor displays the condition of your battery and charging system instantly. It protects the engine computer and 12-volt accessories from damaging surges when jump starting or recharging."
Old 06-19-2015, 02:52 PM
