Banned
Banned but not out, yet..
Plastic is too kinky?
An air cooled refrigerator. ‘Mein Teil’ |
Fleabit peanut monkey
1981 911SC Targa |
Always Be Fixing Cars
What is this, the WRX forum?
'91 964 C4 - New Daily '73 Alfa GTV - 90% done 50% to go '65 912 - Welding in process |
As I am definitely not clever enough to compete with the posts from Bob, Ronnie, and RSBob, I'll just post my little tips and slink off into the night.
1. When I am diagnosing a problem, I always check to see what was recently worked on or could have been disturbed by a recent service. It's amazing how often that can lead you to the problem. 2. I discovered a flip-down magnifier recently and what a difference that makes to an old guy like me. I can read the imprints on the sides of drill bits, and really examine sealing surfaces, worn parts, etc. I recently wired my office and could have never used the Cat-5 crimper without the magnifier. 3. Earlier this year I went crazy at Home Depot and bought all sorts of new fluorescent light fixtures for my garage. It is truly bright in there and my bench is flooded in light. I am much less tired after a few hours of work, particularly when I'm working late in the evening. 4. When using a torque wrench, spotlessly clean threads with no burrs are important. The threads should be either lubed or dry, depending on what the specifications call for. Tightening with a smooth and steady motion gives the most accurate, repeatable results.
1990 964 Coupe 1986 Carrera 3.2 Targa |
Where did you get yours? Comparable to this one? Test, Measurement & Inspection | Optics & Visual Inspection | Carson Optical Mv-23 Magnivisor Magnifier | B496012 - GlobalIndustrial.com
1981 911SC Targa |
If you're going to do actual electrical work, suck it up and spend the money on some good electrical tools.
I rarely want to drop coin on tools when they are 3 or 4 times the price, but once I switched to a high end ratcheting crimper with changeable jaws, and an automatic wire stripper my life was changed. Throw that yellow handled cutter/stripper/crimper POS away. Get a katapult type stripper: http://www.amazon.com/gp/product/B0035KF232 And a ratcheting crimper with a few sets of heads: http://www.amazon.com/Tool-Aid-18920-Ratcheting-Terminal/dp/B0002STTTI And a heat gun: http://www.amazon.com/gp/product/B003N3G4WY Buy bulk heat shrink in a few sizes, and bulk connectors (female and male, no insulation). For the $150ish investment, you'll be making factory level wiring fixes that will NOT be gremlins later on... Edit: I picked that heat gun because it's small, so you can shove it into places (like behind the dash...) where you can't get bigger guns. It's PLENTY hot enough for even the heaviest shrink wrap.
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
camber gauge
![]() ground up 24mm wrench for spring plate height adjusting bolt
1984 911 Carrera Coupe - 32C #73 - M64/05 1998 E36 M3 4dr 2006 Sienna 5dr - the hauler 2004 Lexus GX470 2010 Cannondale Caffeine II - Lefty |
Enthusiasm > Expertise
Use a mirror when doing a two-man brake bleed, so that the guy pumping the pedal can stay abreast of the fluid level. Align the mirror using a laser pointer, eg. an infrared thermometer. A flashlight helps to make the fluid level easier to see in the reservoir.
It's easier to demonstrate this on a non-911; hopefully, this image needs no rotation.
Red Dog Motorsports |
Banned
No such thing as "too" when it comes to kink! Last edited by Ronnie's.930; 06-03-2015 at 12:10 PM.. |
French Import
Sometimes it takes 3 hands to install a plate, washer, etc...
I use a dab of grease on the item and "stick" it where it needs to go. The grease will hold long enough for me to install the nut(s) and tighten in place using both hands when required.
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
Rob
Maverick Region PCA, Fort Worth/Dallas area 1987 911 Coupe, Black M491 3.4 // Turbo-Look Registry # 1249 1977 911 Coupe, Metallic Sienna (I think!)/Lobster SOLD 1982 924 White, SOLD long ago 1966 912 Red, SOLD, totaled a week later by its new owner |
Regarding that mirror to watch the brake fluid level....
An alternative is to use the bottle that comes in this HF kit The vacuum part is garbage and doesn't work, but I ended up using that upside down fill bottle. It auto fills the reservoir as it empties. Works great.
1986 Bosch Icon Wipers coupe. |
ALWAYS suspect the battery first on slow start, no start etc..
Get a good volt meter. Get a good CCA tester I have this one and love it! Worth every penny..... Digital Automotive Battery Analyzer
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
I was removing one of my trunk lid struts
I put a towel underneath to catch any nuts or washers that inevitably drop out of your hand
Chain fence eating turbo
I have one, opposite of what was posted earlier in this thread, use caution when using others advice from the Internet.
I can't tell you how many times I read something on the Internet by those far less mechanically inclined or experienced than I, that simply led me down a rabbit hole - going against what I'd learned from the past. Why? The Internet creates a lemming situation. One person does something, others follow, then the practice becomes accepted and the "expert" method. I've seen it here on the board many times too, not just other forums. Caveat emptor!!!! |
Best valve adjustment tool for cheap goofs like me.. Buy a feeler gauge set like this; make sure you buy one that has the most gauges possible as the remaining gauges not used will become the handle. Snip about a half an inch off the end of the gauge you will be using, place the remaining gauges back in handle, tighten down. Place a band aid on index finger; this will help as the edge of feeler is kind of sharp. Grab the gauge in your hand (the part with all the gauges locked in place.), this becomes the handle, point your index finger, place it on edge of bent, snipped off remaining gauge and push it through using index finger. Learned this from old VW mechanic, works amazingly well, and don’t knock it until you try it.
![]() P.S. I tried the POS tool with the handle and the little itty bitty gauge on the end, snapped that thing in 10 minutes.
72 911 Although it is done at the moment, it will never be finished. Last edited by tobluforu; 08-05-2015 at 03:05 AM.. |
1) I keep a 6" piece of brake booster vacuum hose in my tool kit. This comes in handy for removing/installing the plugs as it grips the tip perfectly and helps to align the plug for screwing in. I can remember the days when a plug would fall out of the socket wrench and I would spend 5-10 min trying to fish the plug out - Never Again
![]() 2) 50/50 Mix of Acetone and Automatic Tran Fluid makes a great penetrating oil. Works much better than PB blaster and others that I have tried (not sure about Kroil but I can never find that at the store). 3) Gibbs Oil - Best stuff for restoring aluminum and magnesium. Spray it on and in a day, all the oxidation will be gone. 4) Obenauf Leather Oil - Great Stuff! 5) Separate toolboxes - metric vs. standard uggh! |
I have a bad neck. I found the best thing for neck support while working on my car was a bag of kitty litter. My creeper often leaves little room to work so lying on the garage floor with my neck supported with the kitty litter bag worked great (just in case you ever have to replace the slave cylinder on the G50). Bag cleans off easy too.
