Banned
Originally Posted by Bob Kontak View Post
Dude. She is so ugly my brother and I both passed her over for her daughter.
Why do you think I recently stocked-up on paper grocery bags?!?!?!
Old 06-02-2015, 04:42 PM
Banned but not out, yet..
RSBob's Avatar
Plastic is too kinky?
Old 06-02-2015, 05:11 PM
Fleabit peanut monkey
Bob Kontak's Avatar
He is a gentleman. He gave her the choice.
1981 911SC Targa
Old 06-02-2015, 05:37 PM
Always Be Fixing Cars
What is this, the WRX forum?
'91 964 C4 - New Daily
'73 Alfa GTV - 90% done 50% to go
'65 912 - Welding in process
Old 06-02-2015, 06:39 PM
As I am definitely not clever enough to compete with the posts from Bob, Ronnie, and RSBob, I'll just post my little tips and slink off into the night.
1. When I am diagnosing a problem, I always check to see what was recently worked on or could have been disturbed by a recent service. It's amazing how often that can lead you to the problem.
2. I discovered a flip-down magnifier recently and what a difference that makes to an old guy like me. I can read the imprints on the sides of drill bits, and really examine sealing surfaces, worn parts, etc. I recently wired my office and could have never used the Cat-5 crimper without the magnifier.
3. Earlier this year I went crazy at Home Depot and bought all sorts of new fluorescent light fixtures for my garage. It is truly bright in there and my bench is flooded in light. I am much less tired after a few hours of work, particularly when I'm working late in the evening.
4. When using a torque wrench, spotlessly clean threads with no burrs are important. The threads should be either lubed or dry, depending on what the specifications call for. Tightening with a smooth and steady motion gives the most accurate, repeatable results.
1990 964 Coupe
1986 Carrera 3.2 Targa
Old 06-02-2015, 08:43 PM
Bob Kontak's Avatar
Went to the "Freight" today. Was going to buy a cheap one for a trial run after reading this tip. It was way too cheesy. It also had a flip down monocle to super amplify.
Where did you get yours?
Comparable to this one? Test, Measurement & Inspection | Optics & Visual Inspection | Carson Optical Mv-23 Magnivisor™ Magnifier | B496012 - GlobalIndustrial.com
1981 911SC Targa
Old 06-03-2015, 08:56 AM
If you're going to do actual electrical work, suck it up and spend the money on some good electrical tools.
I rarely want to drop coin on tools when they are 3 or 4 times the price, but once I switched to a high end ratcheting crimper with changeable jaws, and an automatic wire stripper my life was changed. Throw that yellow handled cutter/stripper/crimper POS away.
Get a katapult type stripper: http://www.amazon.com/gp/product/B0035KF232
And a ratcheting crimper with a few sets of heads: http://www.amazon.com/Tool-Aid-18920-Ratcheting-Terminal/dp/B0002STTTI
And a heat gun: http://www.amazon.com/gp/product/B003N3G4WY
Buy bulk heat shrink in a few sizes, and bulk connectors (female and male, no insulation).
For the $150ish investment, you'll be making factory level wiring fixes that will NOT be gremlins later on...
Edit: I picked that heat gun because it's small, so you can shove it into places (like behind the dash...) where you can't get bigger guns. It's PLENTY hot enough for even the heaviest shrink wrap.
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 06-03-2015, 09:23 AM
midnight911's Avatar
camber gauge
ground up 24mm wrench for spring plate height adjusting bolt
1984 911 Carrera Coupe - 32C #73 - M64/05
1998 E36 M3 4dr
2006 Sienna 5dr - the hauler
2004 Lexus GX470
2010 Cannondale Caffeine II - Lefty
Old 06-03-2015, 10:35 AM
Enthusiasm > Expertise
reddogmotrsprts's Avatar
Use a mirror when doing a two-man brake bleed, so that the guy pumping the pedal can stay abreast of the fluid level. Align the mirror using a laser pointer, eg. an infrared thermometer. A flashlight helps to make the fluid level easier to see in the reservoir.
It's easier to demonstrate this on a non-911; hopefully, this image needs no rotation.
Red Dog Motorsports
Old 06-03-2015, 11:23 AM
Banned
Bob, do you need one of those to help with personal grooming, and other errr, ummm, "personal" activities?!?!?!
No such thing as "too" when it comes to kink!
Old 06-03-2015, 12:08 PM
French Import
zippy_gg's Avatar
Sometimes it takes 3 hands to install a plate, washer, etc...
I use a dab of grease on the item and "stick" it where it needs to go. The grease will hold long enough for me to install the nut(s) and tighten in place using both hands when required.
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 06-03-2015, 12:09 PM
RFP RFP is offline
RFP's Avatar
Originally Posted by stormin48061 View Post
the title got me interested to click on this post. I thought it was a post on tricks on getting stuff put back together on our 911s. One that I'd be interested in reading... is for those that have replaced their hydraulic hood lifts, how in the world did you get the pin and clip back in after you removed them to replace the hydraulic rod with the neat mechanical ones we all bought? My hands and fingers can't get around the wiring down there on the drivers side to push the clip on.... thanks for reading.
Hi Stormin... This drove me nutz too... Here's what I came up with: Easy Left Side Hood Shock Install !
Rob
Maverick Region PCA, Fort Worth/Dallas area
1987 911 Coupe, Black M491 3.4 // Turbo-Look Registry # 1249
1977 911 Coupe, Metallic Sienna (I think!)/Lobster SOLD
1982 924 White, SOLD long ago
1966 912 Red, SOLD, totaled a week later by its new owner
Old 06-03-2015, 01:26 PM
sugarwood's Avatar
Regarding that mirror to watch the brake fluid level....
An alternative is to use the bottle that comes in this HF kit
The vacuum part is garbage and doesn't work,
but I ended up using that upside down fill bottle.
It auto fills the reservoir as it empties. Works great.
1986 Bosch Icon Wipers coupe.
Old 06-05-2015, 06:34 PM
ALWAYS suspect the battery first on slow start, no start etc..
Get a good volt meter.
Get a good CCA tester I have this one and love it!
Worth every penny.....
Digital Automotive Battery Analyzer
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 06-05-2015, 07:43 PM
No, Bob, the one I bought wasn't that nice but it does help a lot though. Bought it from a local indy new and used tool shop.
1990 964 Coupe
Old 06-06-2015, 05:52 AM
sugarwood's Avatar
I was removing one of my trunk lid struts
I put a towel underneath to catch any nuts or washers that inevitably drop out of your hand
Old 07-22-2015, 07:24 AM
Chain fence eating turbo
I have one, opposite of what was posted earlier in this thread, use caution when using others advice from the Internet.
I can't tell you how many times I read something on the Internet by those far less mechanically inclined or experienced than I, that simply led me down a rabbit hole - going against what I'd learned from the past.
Why? The Internet creates a lemming situation. One person does something, others follow, then the practice becomes accepted and the "expert" method.
I've seen it here on the board many times too, not just other forums.
Caveat emptor!!!!
Old 07-22-2015, 09:03 AM
tobluforu's Avatar
Best valve adjustment tool for cheap goofs like me.. Buy a feeler gauge set like this; make sure you buy one that has the most gauges possible as the remaining gauges not used will become the handle. Snip about a half an inch off the end of the gauge you will be using, place the remaining gauges back in handle, tighten down. Place a band aid on index finger; this will help as the edge of feeler is kind of sharp. Grab the gauge in your hand (the part with all the gauges locked in place.), this becomes the handle, point your index finger, place it on edge of bent, snipped off remaining gauge and push it through using index finger. Learned this from old VW mechanic, works amazingly well, and don’t knock it until you try it.
P.S. I tried the POS tool with the handle and the little itty bitty gauge on the end, snapped that thing in 10 minutes.
Old 07-22-2015, 09:18 AM
1) I keep a 6" piece of brake booster vacuum hose in my tool kit. This comes in handy for removing/installing the plugs as it grips the tip perfectly and helps to align the plug for screwing in. I can remember the days when a plug would fall out of the socket wrench and I would spend 5-10 min trying to fish the plug out - Never Again
2) 50/50 Mix of Acetone and Automatic Tran Fluid makes a great penetrating oil. Works much better than PB blaster and others that I have tried (not sure about Kroil but I can never find that at the store).
3) Gibbs Oil - Best stuff for restoring aluminum and magnesium. Spray it on and in a day, all the oxidation will be gone.
4) Obenauf Leather Oil - Great Stuff!
5) Separate toolboxes - metric vs. standard uggh!
Old 07-22-2015, 09:35 AM
I have a bad neck. I found the best thing for neck support while working on my car was a bag of kitty litter. My creeper often leaves little room to work so lying on the garage floor with my neck supported with the kitty litter bag worked great (just in case you ever have to replace the slave cylinder on the G50). Bag cleans off easy too.
Old 07-22-2015, 10:05 AM
