Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
Replaced Master Cylinder, new switch only has 1 terminal
Today I replaced my master cylinder, but my old cylinder has spots for two terminals and the new one only has one. any thoughts on what I should do? I saw a suggestion to leave it off, but I would like to know where it supposed to go.
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 06-07-2015, 08:31 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Do you mean the brake light switch terminal connectors?
Please post a pic
'85 Carrera Targa
PCA/POC
Old 06-07-2015, 10:29 PM
Rennch on YouTube
rennch's Avatar
This one. My original has two spade connectors, and the replacement has one.
Michael O'Neal -
Old 06-08-2015, 02:52 AM
steely's Avatar
Call PP and see if you ordered the correct one?
Your thread title refers to 1 terminal on the switch, but your post refers to the number of switches in the master cylinder.
My '87 master cyl has spots for 2 switches, and each switch has 2 terminals.
I don't know enough about your year or the suggestion about leaving something off.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 06-08-2015, 06:49 AM
That is the wrong type of brake light switch. The one in the picture has a mechanical plunger (black object) which is activated by hydraulic pressure and makes an internal connection to the spade connector. It is typically found on early Mercedes and is also used as a switch for tripping the cruise control when the brake is depressed.
You need a two spade switch as mentioned in earlier posts.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 06-08-2015, 07:00 AM
Rennch on YouTube
rennch's Avatar
This was the option from pelican. No worries, thanks for the help.
Michael O'Neal -
Old 06-08-2015, 07:16 AM
