Removing dashboard heat and fan controls
Does the front plate come off or do you have to dig into it??
Old 06-08-2015, 01:38 PM
How did you get that out??
Old 06-08-2015, 02:07 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
ON OUR CAR, THE FRONT PLATE DOES NOT COME OFF.
Here's a pic.
Check the Bentley. It's not a "fun" job.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 06-08-2015, 02:08 PM
Picture.
The pic I posted is from Google.
If I recall, there are two nuts holding the assy to the dash.
I have never removed these controls.
What are you trying to do?
1986 911 Targa.
Only in L.A.:
Old 06-08-2015, 02:10 PM
There's a problem with one of them being stuck and Or broke need to get inside.
Old 06-08-2015, 02:42 PM
I already figured a two day job
Old 06-08-2015, 02:44 PM
I figured it out. First remove the radio then look in behind heat controls,there you will find one 10mm nut attached to firewall that needs to be removed.After that remove cables from the trunk and pull out.A major pain in the butt I might add.
Old 06-09-2015, 02:38 PM
Removing dashboard and fan controls
I just removed mine to do a cosmetic restoration and to figure out why my fan won't turn on. As others noted, it is a major pain to get it out. The control itself isn't too bad, if you're lucky enough to have slack in the Bowden cables. Note there are three grommets, one for each cable, where they pass through the bulkhead. You have to remove the grommets in order to pull the cable housings out, at least from inside the cabin.
Old 06-09-2015, 06:23 PM
i found a replacement but havnt pulled out the cables yet thanks for the heads up.
Old 06-09-2015, 06:59 PM
Walt Fricke's Avatar
When I had mine out, some part of the attachment system broke - perhaps what held the plastic facing to the steel backing? Easily solved by drilling four small holes, and using some black headed screws, which blend right in.
The switch for the fresh air blower motor is something Dr. Porsche (Ferdinand) could easily have designed, or purchased, in 1899 - exposed contacts, with a wiper on the end of the arm. Mine had basically burned out. I replaced them with the multi-position rotary switch used for the AC (if you had that), so it looks fine in the dash.
Now if I could figure out a replacement for the blower motor. List members have several times said buy X from NAPA, and make a plate like this, and so on. However, X turns out to be something which would work fine, with the plate type stuff, for the rear, engine mounted, blower. The front blower is a sort of open design housed in the plastic casing of the air handling system.
Old 06-09-2015, 07:07 PM
universeman's Avatar
I bought the original Bosch motor on eBay for $80. It had a different number, but when I got it in and replaced it, it's identical. PM me if you want to know more.
Jason - Austin, TX
82 911 SC targa (gone, but not forgotten)
92 968 coupe
Old 06-09-2015, 07:32 PM
I don't really want to replace the motor I have, bought used to replace the previous one, with another used original. They don't last all that long, and start to shriek, so they become useless.
What I want to do is replace the original motor with one which is more reliable. But that is no simple task, as the plastic case is designed to hold the short but kind of tall original.
Old 06-09-2015, 09:27 PM
That's what happened to mine the plastic broke away from the metal ( really poor design).
Old 06-10-2015, 04:25 AM
