rust and pitting inside 915
Hi Everyone
I have a 915/63 Limited Slip transaxle that I use in my race car (79 911sc). I have been having problems with grinding while shifting into 3rd gear, and difficulty getting into 5th. I have new coupler bushings, new shift tunnel bushings and a new cup for the end of the shifter.
It has been at least 5 years since the gearbox was rebuilt (by a previous owner), so I assumed that it is time to get in there and refresh everything.
When I disassembled it today, I found a large amount of rust inside. There is also significant pitting on the shafts and the gears.
My question (for now) is: is this anything to worry about? Since it is a race car, I don't care about noise.
What would cause this? It is stored inside, in an unheated garage, over the winters.
Thanks!
Old 06-14-2015, 06:00 PM
The only thing I've seen cause rust/pitting in a gear box is the combination of moisture with lack of lubrication (as in no oil was in the gearbox or the gearbox had not turned for a significant period of time).
Did you clean anything before taking that picture? I don't see any evidence of oil film in that photo.
Old 06-14-2015, 07:11 PM
gearhead
How much oil came out when you drained it? That's pretty ugly.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 06-14-2015, 07:31 PM
Almost Banned Once
sc_rufctr's Avatar
Ugly but it wouldn't stop me using it.
Just replace what's worn and slap it back together.
- Peter
Old 06-14-2015, 08:44 PM
About 2 1/2 liters came out when I drained it.
Old 06-14-2015, 11:39 PM
I'm wondering if that is what happened the last time it was rebuilt. The bearings don't have any rust or pitting on them.
Old 06-15-2015, 12:15 AM
2.6 L is very low. You should get close to 4 liters. Although, I would just clean it off, replace what is worn, and use it.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 06-15-2015, 02:03 AM
Yes, it is low. I am religious about checking engine oil level, but despite the drips on the garage floor, I never "got around" to checking transmission oil.
The reason I measured it when it came out was that I was suspecting that low oil level might have contributed to my shifting problems. Is this the case?
Also, is there any benefit/detriment to cleaning off the rust (i.e. by bead blasting?).
Thanks everyone!
Old 06-15-2015, 06:08 AM
gearhead
Show pictures of the pitting up close. How does your crown wheel and pinion look?
I tell my race customers to change their oil every 6-8 events.
1974 914 Bumble Bee
2009 Outback XT
Old 06-15-2015, 06:29 AM
Actually, it would have been 5 events between oil, so I am not that far off...
Here is the crown wheel and pinion.
Old 06-15-2015, 09:37 AM
gearhead
Other than the surface rust, I'm not seeing anything particularly scary. Look really closely at 2nd and 3rd gear. Those are the high use gears and the ones that wear through the heat treat and break off teeth. However, I don't understand why the oil would be so low after so few events.
1974 914 Bumble Bee
2009 Outback XT
Old 06-15-2015, 10:18 AM
Reiver
Reiver's Avatar
How is your air vent oriented? If in wrong (hole should point forward direction of travel if memory serves) it can suck oil out of the case giving you a low level and allowing for moisture to do whatever to exposed parts that set for a bit.
De Oppresso Liber
Strength and Honor 5th Legion
Old 06-15-2015, 12:50 PM
The air vent is properly oriented. I didn't do the latest fluid fill (my shop did), so I can't say for sure that the correct amount was put in in the first place, but it has been leaking for a while - drips here and there, but never forming a puddle. I suppose you add up all those drips, and it could come to something significant like this.
Old 06-15-2015, 02:05 PM
