Any tips on how to remove this effectively
Member 911 Anonymous
Heat Gun on Low settings, do not place in one spot too long. It will soften up and peel. Use gloves it will be hot.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Rescuer of old cars
Then follow up with 3M adhesive remover.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
No heat gun, hair dry work??
Will let you know Thanks. |
RETIRED
Nope....splurge on a Makita heat gun.....good tool to have.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Be careful with that thing. It'll set certain materials on fire (ask me how I know!). They are great but there's times a hair dryer with higher volume and lower heat is good too.
1986 911 Carrera Coupe 2016 VW Golf R 2008 Toyota Highlander (given to kid) 2021 Kia Telluride 2020 BMW R1250RS |
for the limited use i need a heatgun for i picked up one at harbor freight for a few bucks. it's worked great for the last couple of years.
- He gave his father "the talk" - Once while sailing around the world he found a shortcut - He taught a german shepard how to bark in spanish He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends. |
76 911S Targa
Depending on the paint you can use an adhesive removing solvent. If it is a two part paint which is mostly used these days, you can remove old adhesive with methyl ethyl ketone, MEK. If you have a hand rubbed lacquer finish, stick with the heat gun and patience.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods. |
Mineral oil (butcher block) and coconut oil work surprisingly well on removing a variety of adhesives. Worth a try if you have some on hand.
++++++++++++++++on HFT gun!!!
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
Almost Banned Once
Also... Olive oil is worth a try.
- Peter |
Another plus for the HF heat gun. Cheap, but they get the problem done. I did my entire vinyl wrap project with a HF heat guns
![]() Good luck removing - those things are so tedious to remove.
-Derek '84 911 coupe |
![]() Returning Member after 10 year Absence |
Yep! a big can of worms.
I've got quite a bit of time into this so far. Hair dryer on hot, and a plastic scraper. I though the adhesive would be quick to remove but that's no walk in the park either. Goo gone did nothing. 3M adhesive remover at least softens it up so it can be scraped, then rubbed off. It took me 3 hours to learn how to do the first 4 inches, 1 hour for another 4 inches, and 1.5 hours to get the remainder off. Adhesive part, I've got 2 hours in. Should be able to get the rest off in 1-1.5 hours. The other side should take considerably less time, the trial and error part are done.
Randy 73.5 911 T 97' C2S 06' C2S |
Schleprock
Need to be patient with the adhesive remover solvent. Can't just dab it on with a paper towel and rub. Need to pour the solvent on the adhesive and let it sit for a while to allow the solvent to penetrate the sticky stuff before starting to scrape on it.
Kevin L '86 Carrera "Larry" |
2nd. In fact, I'd recommend gently heating the adhesive first, then using the solvent.
RETIRED
I'm still recommending a Makita on low. A beyotches hair dryer will NOT do the job.
Only thing that worked for me was the heat gun at a low setting, followed by 3m adhesive remover and plastic scraping tools. 3hours a side at least.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
