Rene (guest)
Guest
Posts: n/a
Hi! I have a 911 3.0 1977, I changed oil but I have problems adjusting oil level. I used 12 qtrs, the gauge level indicador mark empty and using the dipstick marks the minimum. I follow the instructions, I mean checking the level with the engine running at idle and at operating temprerature. If I add more oil causes smog because the oil excess... Colud you help me?
This post was auto-generated based upon a question asked on our tech article page here:
Old 07-01-2015, 08:39 AM
I usually like to drive the car hard and recheck if the amount you put in doesn't add up with what is on the dipstick. Sometimes the thermostat doesn't fully open when the car is idling, a quick spirited drive should bring the level up on the stick.
- Casey
Eva
911SauCy's Avatar
Rene, so long as the car it at full operating temperature, the dipstick is not lying.
If it's at temp, idling and being checked on a level surface, showing minimum, add another half quart.
The overall quantity is dependent on other factors like what type oil coolers you may or may not have. When I added a large front cooler to my SC, the car took 14qts to get the line on dipstick to mid point between min-max. That was after about half hour of driving around, checking, adding, checking, adding...
Casey, there's no need to drive the car hard, just to get it to operating temp. for an accurate reading.
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 07-01-2015, 09:06 AM
Air Cooled
Craig_D's Avatar
Post needs a longer title..
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat"
'99 Honda VFR800Fi, '98 Honda SuperHawk
'88 Honda Hawk GT, '77 Honda CB750K Cafe
'69 Honda CL350
Old 07-01-2015, 09:34 AM
10 qts with a filter usually gets the level 1/2 way between the marks on the stick. Don't see how you could be low after adding 12 qts unless the engine was new, oil lines empty and not run yet.
206 637 4071
Old 07-01-2015, 09:40 AM
Fleabit peanut monkey
Bob Kontak's Avatar
I think a peppy drive is warranted. No idea where Rene is. He may be in Australia? If the car is just idling in cold weather (from cold start), it will not open the thermo.
To remove all doubt, put your hand on the front fender oil cooler/oil lines up there. They will be warm when the thermostat is open.
1981 911SC Targa
Old 07-01-2015, 09:43 AM
Reiver
Reiver's Avatar
Does it have an aftermarket or Carrera oil cooler on it?
De Oppresso Liber
Strength and Honor 5th Legion
Old 07-01-2015, 04:19 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Seen a lot of those lately, they either "auto-generated based upon a question asked on our tech article page here" or sponsor by Nick at Pelican Parts
Who Will Live... Will See
Old 07-01-2015, 04:28 PM
Swapper and Ruiner
not_hans_stuck's Avatar
Best thread title.
http://forums.pelicanparts.com/paint-bodywork-discussion-forum/502929-diy-iroc-rsr-conversion.html
http://forums.pelicanparts.com/porsche-911-technical-forum/649179-rsr-ls-conversion.html
Old 07-02-2015, 07:36 AM
redturbo911's Avatar
Make sure to get the engine warmed up well and recheck.
Tony
91 964 c2 black/ Work in progress/Finally back on the road
85 EURO 930 Black slightly moded slowly reviving her
77 911tt EFI wide body red/ Slightly modified SOLD
Old 07-06-2015, 09:24 PM
Functionista
manbridge 74's Avatar
I'd second the 10 qts.
Also make sure you have the correct dipstick as there were different lengths/markings over the years.
Old 07-06-2015, 10:02 PM
