| Rennch on YouTube |
				What engine crossmember and tins do I need for a 3.6 conversion?
			Hey all, I get my 3.6 on Friday, and I need to start the conversion process to fit into my 69 911T. I'm told I need a new crossmember and I need some tins to start with so I can modify them. Anyone know which ones I can use? Our host sells the Rennline RSR version, but I'm not sure if that will work. Also, do I start with 3.2 tins and modify from there? Thanks. This is question 20 of 356 in regards to this engine swap.
				__________________ Michael O'Neal - 69 RSR Clone(ish) - The build: http://bit.ly/69porschersr 69 911S Blasphemy Build on YouTube Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/ | ||
|  07-01-2015, 06:02 PM |
| non-whiner Join Date: Aug 2012 Location: Slightly right of center
			I used the 3.6 tins on both of my swaps (74 and 84). I also used the Rennline engine grace:
				__________________ "Too much is just enough." | ||
|  07-01-2015, 06:30 PM |
| Rennch on YouTube |
			mreid, that's good news!  Did you use just the crossmember, or does it need a new pulley cover as well? And what mods did you need to make for the tins?
|  07-01-2015, 06:46 PM |
| Registered Join Date: Jan 2009 Location: Marietta, Ga (Atlanta)
			If you keep the 3.6 engine mount console and crossbar, you will need to modify the cross bar or "bow/bend" it forward to bolt up to the motor mounts. It's because the console is deeper and sits further to the rear. I took this pic from your previous thread, showing a modified crossbar. I have the same modified bar on my 3.6 in my '80SC and it works great. The plan/diagram is somewhere on this forum in one of the transplant threads. If I can find it i'll let you know. Also, I have a 964 3.6 in my car and used the 3.6 tins with absolutely no problems or modification. [IMG]  [/IMG]
				__________________ '80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa Last edited by uwanna; 07-01-2015 at 08:17 PM.. | ||
|  07-01-2015, 08:06 PM |
| Registered Join Date: Jan 2005 Location: SC
|  07-02-2015, 02:11 AM |
			and here's a better pic of the results and fitment. I also reinforced the ends of the crossbar with 1/8" plate steel and then drilled a few holes in it to lighten. I did trim my 964 tins on the corners as seen here.....to clear a weld-flange on the '83 SC body. This "cutout" of the tins also allowed me to access the mounting bolts from below.....not required but seemed a benefit at the time. [IMG]  [/IMG] | ||
|  07-02-2015, 02:21 AM |
				 | Quote:
 Here are some construction pics of the modification. (not mine) I purchased my bar already modified from a Pelican.
				__________________ '80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa | ||
|  07-02-2015, 06:05 AM |
			I used a console and brace from a 3.0/3.2. Bolts right up. I removed the heat shield from the rear engine tin and welded up all the holes. Everything then bolted right into place.
|  07-02-2015, 09:37 AM |
| Registered Join Date: Oct 1998 Location: Denver, CO
				 | Quote:
 Also think about where you want to mount your coils. I welded on a plate at the same time to mount my coils. This is the best photo I can find right now and don't have the car nearby to get a better pic. Look on the lower left. Then think about your plug wire lengths from the distributors, etc. Some mount the coils on the left side of the engine bay.
				__________________ - '72 911T - '81 911SC Euro | ||
|  07-02-2015, 04:06 PM |
				 | Quote:
 I had to retain the 3.6 console and bar to continue to use the AC mount.
|  07-02-2015, 04:42 PM |
If I remember correctly, the 3.0/3.2L mount eliminates the A/C mount.  So it is cleaner too...
|  07-02-2015, 05:47 PM |
				 | Quote:
 Besides, if I ever wanted to sell my car here in the south, not having air is a non starter!
|  07-02-2015, 06:14 PM |
| Rennch on YouTube |
			I think I need to source a 3.0/3.2 console then.  I can get the Rennline RSR crossmember to bolt onto it.  I'm also in need of 3.0 engine tin, right?
|  07-02-2015, 08:41 PM |
No I used the 3.6L tins with the 3.2 console.  The 3.6L tins have holes, etc for your lower plug wires.  There will be gaps though that you have to fill.  My guess is that it'll be easier to use the 3.6L tins than adapting the 3.0 tins to your motor.  Other opinions?
				__________________ - '72 911T - '81 911SC Euro Last edited by arrivederci; 07-03-2015 at 10:06 AM.. | ||
|  07-03-2015, 10:02 AM |
| Rennch on YouTube |
			I have the rear and the side 3.6 tins.  I don't have the console or the crossbar.  So, if I get that rennsport RSR crossmember, all I need is a 3.0/3.2 console to bolt it up to.  That sound right to you guys?
|  07-03-2015, 10:31 AM |
Yes, and different studs to mount the console.
|  07-03-2015, 10:33 AM |
| Rennch on YouTube |
			Ok, roger that.  Thanks.
|  07-05-2015, 10:30 PM |
| GOM (Grumpy Old Man) Join Date: Mar 2008 Location: Seattle WA
			I'm in the process of doing the same conversion and have some questions for peeps that have already done this. I am going to use a 964 crossmember, console, and tins. I'm going to modify the crossmember as shown in post #7 of this thread. Questions: Do I need to add a spacer to the crossmember in order to lower the engine to fit? If so, how far? Did anyone modify the 964 console to create a cover for the crank pulley or did you run it as-is? The 964 console really doesn't provide much protection and I wonder if it will seal properly once installed. Thanks in advance! This is my first conversion ever and I am shooting in the dark on a lot of stuff. Jim
				__________________ Instagram: @3pedalposse | ||
|  11-30-2016, 08:43 AM |
| Registered Join Date: Nov 2013 Location: sf bay area
			trying to revive this thread as i’m doing a 964 3.6 swap on my 71. can anyone post more pics of the concole differences between the 3.0/3.2 and one from an earlier car like from a 71? looking online i see its interchangeable from 65-83. i hear the depth is the key difference and can mean dropping the motor to change the fan belt .  can someone also repost the mod uwanna or pdtweaks posted? they’re not showing up anymore. thanks
				__________________ 1967 911 (Azzuro Thetys) - #308439 1971 911 (PTS Black) - Built 3.6 Sleeper 1989 911 (Grand Prix White) - Cabriolet Bone Stock | ||
|  02-25-2018, 06:08 AM |
				 | Quote:
|  02-25-2018, 07:27 AM |
