3.0 SC - Switching to 3.2 Carrera intake manifold and keeping CIS?
Hi,
I think my airbox is cracked and I'm thinking of replacing it with the 3.2 Carrera intake manifold but I haven't decided if I should do the EFI conversion or which one I'd do, so I'm wondering if I can just replace the manifold and keep the rest of CIS in place.
Is this possible?
Thanks, Michael
Old 07-04-2015, 03:47 PM
ROW '78 911 Targa
timmy2's Avatar
Anything is possible, but this idea probably won't work, cheaper to buy a new air box.
Take a look at photos of both systems and then:
Just think about where and how you would mount the mechanical fuel distributor with the air metering plate?
And more...
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 07-04-2015, 04:10 PM
964 Intake Manifold
I'm also wondering if converting to a 964 manifold might not be a bad idea, I can get one on ebay and the price doesn't seem to bad if I don't need to buy too much else?
e.g.
Genuine Porsche 964 Metal Intake Manifolds & Rubber Sleeves | eBay
Old 07-04-2015, 04:13 PM
Hi Dennis,
Thanks for getting back to me - yeah that makes sense. I'm just wondering how much of a 'system' I could reuse if I upgraded to a 3.2 intake/throttle body/injectors/DME. Same goes for a 964 system - I know I'd need the manifold adapters and I guess a EFI like the megasquirt but would I be able to reuse the rest, e.g. rails and injectors.
I see you've done the EFI conversion, how's that working for you?
Regards, Michael
Old 07-06-2015, 07:40 AM
moparrob's Avatar
Check out the Bitz systems. Pretty simple to set up and uses modern EFI with good base map provided.
Old 07-06-2015, 08:04 AM
