Runnin on empty
acme911's Avatar
Need help to identify this model BBS
Hi, First time post.
I just bought a '74 911 with a steel wide body. The BBS wheels on it are unusual. I've seen my share of BBS wheels (I'm 58). Tried to find similar pic on the web. Nothing.(Currently have '76 w/'82 3.0, Carrera Flares),
So let the pic's speak for themselves.
As you can see that it has unusual offset. 12"x 15", Front is similar.
Any help is greatly appreciated.
Asking because I want to replace tires with PZeros 335/35/15 and 225/50/15 as the originals are P7's from back in the day.
Also car was from a private collection and stored since '96. It's in great shape, no rust. And the car was located only 60 miles away from my house.
Cheers, Andy
Old 07-07-2015, 08:51 PM
Rescuer of old cars
Arne2's Avatar
Can't remember the model designation, but those are some older BBS Racing 3-piece wheels. No drop for tire mounting - the wheels must be disassembled to change the tires. As I recall, there is an aluminum plate with o-rings sandwiched between the rim halves. New o-rings may be difficult to find.
Hated these wheels when I worked in tires.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 07-07-2015, 09:33 PM
Bbs e51
Old 07-08-2015, 01:06 AM
Runnin on empty
acme911's Avatar
Thanks Guys
Old 07-08-2015, 07:49 AM
KTL KTL is offline
Schleprock
KTL's Avatar
rgofast (Rod) here on the forums could give you some additional tips about these wheels. He restores BBS wheels.
Custom BBS Motorsport Wheels | Graff-Haus
Also, these wheels may be the type that use unique lug nuts?
Kevin L
'86 Carrera "Larry"
Old 07-08-2015, 08:19 AM
Rescuer of old cars
Arne2's Avatar
That is my recollection as well.
2018 718 Cayman 2.0
Old 07-08-2015, 09:22 AM
Banned
Now, why you need to take apart the wheel in order to replace the tire??
Old 07-08-2015, 11:58 AM
Rescuer of old cars
Arne2's Avatar
To change a tire on a normal wheel, you push one side of the tire bead down into a well (or "drop center" in the middle of the rim, which allows just enough room to stretch the bead over the rim edge.
These wheels are essentially flat in the middle, no drop or well. So you can't stretch the tire bead off the rim.
2018 718 Cayman 2.0
Old 07-08-2015, 12:14 PM
BBS E52 is the model. are they for sale?
Old 01-15-2016, 04:02 PM
Runnin on empty
acme911's Avatar
They were identified as E51's. I pulled them apart and had the centers powder coated satin black and then I polished the front halves. Replaced the gaskets and bolts. It took a while but I think it was worth it. Thanks for the interest.
'74 911, Steel Wide Body Hotrod, 3.0, Jenvey ITB’s, AEM Infinity, KW V3's, Eibach Sways, JWest shifter and other stuff.
https://forums.pelicanparts.com/porsche-911-technical-forum/1006126-midi-modded-bumpers-led-headlight-manifold.html
Old 01-15-2016, 04:29 PM
