Lucky Luca
Horrible Fuses!!
Hello,
I was checking the fuse box since I had problems with the rear light (FYI I opened/closed a post about) then I faced this (please see pic attached)...HORRIBLE!! Is it normal? On first fuse: the wire below the fuse is not well connected..so it could be the reason of my battery bleeding Second fuse: very poor condition...must replace it.. the strange thing is that circuit is for the hazard light that is not mounted on my '74 2700 911... ![]() PS: Please also note how generous was Porsche...some fuses are not connected to anything...but in case are ready to be!
______________________________________ Porsche 911 2700 1974 Gelbgrun Honda CB 400 F SuperSport 1976 Candy red Yamaha FZ750 1985 Grey/Red |
Try hard to find ceramic replacement fuses. Don't bother with the cheap plastic core fuses available at the local auto parts store. Many different German cars used them in the past. VW is a good source for them.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Try this: http://www.amazon.com/Littelfuse-0GBC008-VP-Ceramic-Volt-Carded/dp/B000COA324
Or this: New company and new products. 'Classic Retrofit' 911 Fuse Panel and CDI+ ignition.
Jason - Austin, TX 82 911 SC targa (gone, but not forgotten) 92 968 coupe |
A lot of work to go through for a 20 cent fuse.
Our host sells the ceramic fuses. Given how faded in color yours are I'd probably replace all of them.
Seeing that you're in Italy, however, shipping from our host would probably be an issue...
1987 911 Carrera coupe - Guards Red 2010 997.2 C4S 6-Speed 2005 Mini Cooper Convertible (R52) - Wife's car 1977 VW Bay Window Camper Bus |
I have been using BUSS type GBC glass fuses for over 25 years. They are pointed at both ends. My car sat for 10 years and on re-awaking, I have had no electrical problems. they come in 8, 16 & 25 amp ratings
Tom
68 Beetle 68 to 72 sold 72 911T Nov 71 to present P/U @ factory Nov 19. Car was gift to myself for surviving the army 67 VW split window 74 to 76 sold 81 VW caddy 81 to present |
Just plan on replacing all of them.
I found a couple of mine were the wrong ratings, bound to happen after plus 30 years.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
These look like the best solution for all future problems. Takes some effort, but well worth it.
1982 911SC Wine Red Metallic OMG I love this car! |
Reiver
Crappy fuses only worked for 42 years....
De Oppresso Liber Strength and Honor 5th Legion |
ROW '78 911 Targa
This^^^
![]() Just clean the posts, tighten the wires and replace the fuses. Should be good for another 20 years. If the fuses are blowing, it is something else causing it.
That may be, but speaking from experience, you never know what creative wiring the PO did. In my case there were major loads connected straight to 12V, no fuses on either AC fan! A fire waiting to happen. Worn out is worn out, period.
I installed a panel from Fred Cook and am very happy with the result, but there are several options out there. Goodbye crusty old fusebox, hello Fred Cook!
1981 911SC restomod "Minerva" 2004 Boxster S 2021 Cayman GTS 4.0 manual "Olive" 2014 Cayenne GTS V8 (wife's lover) The slope is not slippery; in fact it is entirely frictionless. |
Been here a while
While it may appear that there are many fuses without wires going to them, the 'input' side of the fuse box is bussed on the backside so only those fuses for features you don't have, power windows, sunroof, ac, etc are extra or spares.
looking for 1972 911t motor XR584, S/N 6121622 |
Lucky Luca
Yes definetely not worth to buy ust few fuses...I'll take advantages of the situation to buy more stuff just to share the delivery costs..that's what I said to my wife (and to my conscience).
Very nice the Classic Retrofit items.
I got a couple sets of these (they're very nice german made ceramic) and replaced every fuse in the car. Clean the connections with some DeoxIT and ensure the spring action is tight.
Straight shooter
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
