Cylinder 3. What is sensor and how do I get it out?
After sitting on the engine stand for the last year it is time for the rebuild to begin. Having some trouble removing tthe sensor located on the forward side of cylinder 3. I cannot get a wrench on it and it looks like it is meant to be taken out with a socket due to the cutouts in the cooling fins. The wire does not seem like it has an electrical connection fitting allowing it to slide off the end and I don't want to pull to hard. On the other end of the wire it looks like it has been cut at some point in time and then rejoined and heat taped. Is this the correct method?
Old 07-22-2015, 10:18 PM
Old 07-22-2015, 10:19 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
It's the CHT (cylinder head temperature) sensor. Not sure but there might be a special socket similar to a spark-plug socket that you put on it and then use an open box wrench on that. Or see here for a home-brew: CHT Sensor Replacement
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 07-22-2015, 10:56 PM
We use a deep 14mm 3/8" impact socket which has a long slot cut in the side with a cutoff disc to clear the wire. The early ones are 13mm. A non-impact socket is too flexy when cut. Don't over tighten when you reinstall it or it can shear off in the head.
206 637 4071
Old 07-23-2015, 05:14 AM
midmoto's Avatar
I just did that on my 86, I took an old snap-on 14mm and had a friend cut a long slot in it with a lathe. Worked great.
Old 07-23-2015, 05:53 AM
Thanks guys for the help - appreciate the links too! Lots more questions coming soon I am sure.
Old 07-23-2015, 07:25 AM
KTL KTL is offline
Schleprock
KTL's Avatar
I used a flare nut wrench
Kevin L
'86 Carrera "Larry"
Old 07-23-2015, 10:55 AM
looks like yours is the newer 2 wire version. When my one wire version went bad, I simply cut the wire, used a "standard" socket and replaced with the updated 2 wire version.
You might want to do a cost/benefit comparison between modding the socket and simply replacing the sensor?
Old 07-23-2015, 11:18 AM
