Alright....
3.2 motor - how to disconnect head sensor
Happy Labor Day!
I was wondering if anyone could shed some light on how to disconnect the head sensor on the front of a 3.2 motor. My goal is to remove the engine tin, not the senor. But I cannot figure out an easy way to do it. Does it just unscrew? ![]() ![]() Any suggestions?
Stephen Friendswood, Texas '78 Targa w/ '86 930/20 w/ '74 915/06 |
Member 911 Anonymous
If it is the old OEM, it is a 13MM deep socket. Cut the wire off.
Install: Use a grinder and make a slotted 14MM deep socket tool to put on the new updated CHTS. Be very careful not to cross thread, the head is only aluminum.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Alright....
Well for $95, I'll just work around the sesnor.
Thanks!
13mm Socket With Cut-out
You can remove it and save the wire by either making or buying a socket with a cut out:
![]() Good luck, Gordo
Don "Gordo" Gordon '83 911SC Targa |
$95?
That's why we cheap basturds sacrifice a HB socket
Mine broke off. Your milage may vary.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
