Len 911's Avatar
Where to start
OK here is the problem that I am having,
I can be driving along and the car stops running, like no fuel just stops running. Cranks over fine. I can pull over and wait and some times it starts back up, other time it take longer. I have a new fuel pump, thought that was the problem NOT.. where else should I look or test. Could it be the coil ? Fuel pump relay ? or is there something else I should be looking at.
seams to be getting worse, before seems like I had to be driving awhile but not now happened this morning 2 min into the drive. pulled over cranked a little started right back up.
Where to start looking....or replacing parts
It is a
1985 euro, 911, 3.2 , Stock
New battery
Fuel Pump
Alternator
Old 09-14-2015, 06:12 AM
theiceman's Avatar
dont replace parts .. trouble shoot ..
see if you have spark when i dies . also you dont state what car you are driving, that would help ..
helps to have a someone with you though to check spark ..
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 09-14-2015, 06:31 AM
ROW '78 911 Targa
timmy2's Avatar
Try spreading the fuel pump relay pins with a razor blade and see if that helps.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 09-14-2015, 08:29 AM
1988 Carrera
shadowjack1's Avatar
Filter?????
88' Carrera
79' SC gone (lost to Katrina)
75' Targa gone
72'914 gone
72' 914 gone too
Old 09-14-2015, 08:30 AM
Len 911's Avatar
New filter..I just speak the pins and cleaned them. Will see what happens. .keep the suggestion coming....I have been pulling my hair out and I don't have much to pull.
Old 09-14-2015, 09:05 AM
Project Addicted
I will guess that the DME fuel pump relay is starting to go.
Jon
1966 912
1976 911 3.4 Backdate Project
1986 944
Old 09-14-2015, 09:34 AM
T77911S's Avatar
dont jsut replace parts.
check for spark when it will not start.
DME relay
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
while I agree with T77911s comment that you should not just replace parts, this sounds very similar to what happened to me when my dme relay started failing -- one thought -- locate the dme relay (under the driver's seat, small black plastic rectangular box behind the DME computer (the bigger silver rectangular box) and, when you next have this problem, give it a sharp tap and see if anything changes. The soldier joints on the relay will go bad over time and cause intermittent problems similar to what you're seeing.
At a minimum, since these can/do go bad and cause mysterious issues when they do, it's a good idea to pick up a second DME relay to have as a spare -- If you can find one locally/quickly, I'd start by replacing the DME relay and seeing if that doesn't fix your issue
Old 09-14-2015, 10:10 AM
Len 911's Avatar
Is there a certain brand DME to get. I see Pelican has different ones ....What one should I order?
Old 09-14-2015, 11:19 AM
Project Addicted
The OEM is the only one to trust. The Uro part has been known to be DOA.
Jon
1966 912
1986 944
Old 09-14-2015, 11:26 AM
theiceman's Avatar
wouldn't THAT be a total kick in the nads, troubleshooting a no start issue and put in a bad DME relay out of the box ..
Old 09-14-2015, 11:45 AM
Undocumented User
McLaren-TAG's Avatar
Here's a good basic no start troubleshooting guide.
Pelican Technical Article: 911 Carrera Engine Starting Troubleshooting
Once you rule out the basics, you'd be looking other things. I had a similar sounding no start when warm issue it turned out to be the speed reference sensors, there are also issues introduced with a bad CHT sensor.
Old 09-14-2015, 11:48 AM
Len 911's Avatar
Found a YouTube video that shows how to repair the DME..sure enough the solder joints had cracked. I resold re soldered the joints..we'll see what hsppens..I'm going th o order a new one just to be safe and keep this one as a spare...
Old 09-14-2015, 05:11 PM
T77911S's Avatar
if you can solder you may try hitting all the joints with an iron (soldering that is)
RACE CAR:: sold
Old 09-15-2015, 04:13 AM
Fuel pressure regulator , car starts and seems fine then just stops
Cranks right back up like nothing happened.
When the regulator is bad it surges gas and the increase in pressure
The brain then shuts the car down. Use the Volvo regulator
Same part much cheapet.
Don't buy the hype it's a simple job
Old 09-15-2015, 04:28 AM
Len 911's Avatar
Would you know what year Volvo or part number to look for..
Old 09-15-2015, 07:41 AM
Looks like it's a Bosch 0280160215
see - http://www.amazon.com/Bosch-0280160215-Fuel-Pressure-Regulator/dp/compatibility-chart/B001CO6J3K
Old 09-15-2015, 08:12 AM
theiceman's Avatar
Wow you are ordering a whole new DME ? that's not gonna be cheap ..
Old 09-15-2015, 08:30 AM
What coil? Any Tach issues?
Old 09-15-2015, 08:37 AM
Len 911's Avatar
No tach issues..coil ? I will have to look. It is under a black plastic housing...as for the DME just the fuel dme black box with 6 pins or so..I opened the fuel dme and the solder was broken..
Old 09-15-2015, 09:19 AM
