Idle question
Hello I have a 79 Porsche 911 sc that idle very high on cold start. will someone please explain to me what to disconnect. I dont want that high idle anymore. I'm a long time member here my car been park for years. and I'm about to put it back on the road. anyways thank you for your help I will report back here.
sylvester
Old 09-30-2015, 07:14 PM
Member 911 Anonymous
DRACO A5OG's Avatar
I am not sure about the SC but I think it also has a 45 second to 1 minute initial warm up idle which will be higher than normal.
How long before it settles down or does it?
'85 Carrera Targa
PCA/POC
Old 09-30-2015, 07:24 PM
Reiver
Reiver's Avatar
You don't want to change the designed operational system...it's there for a purpose.
How high does the idle go and for how long....once it abates what is the idle when warm.
You can adjust your idle by adjusting your CO at the fuel head if the mixture is off and then adjust it near the accelerator cable...the CO should be checked first (air fuel ration) if it's been sitting awhile and then the fine tuneing of the idle.
De Oppresso Liber
Strength and Honor 5th Legion
Old 09-30-2015, 07:33 PM
if you want to really fix it youll have to modify the AAR. its just a matter of removing it and knocking a pin. the mod just changes the start point of the disk inside so from cold start less air gets past it
Jason
81 SC
97 328is
87 Jeep Comanche (RIP)
Old 09-30-2015, 10:19 PM
T77911S's Avatar
the hi idle is there for a reason. 1200 is about normal. unless it is above 1500 i would leave it alone.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 10-01-2015, 04:10 AM
Chain fence eating turbo
You want the engine to idle high cold to aid heating up engine as quick as possible and prevent stalling.
Old 10-01-2015, 05:52 AM
