It's a trap...
Speed Buggy's Avatar
Location: 1/2 way between the Motor City and the Glass City.
Question Squeak squeak..I did search, no help.
I have a squeak coming from the rear of the car. It is consistent with wheel speed, not engine speed. It only occurs under non-load conditions. When I push in the clutch or slow down it starts, It goes away under load. I just put the engine back in the car. New clutch, flywheel machined, new CV joints with schnoor washers, new pads and rotors. Any ideas? Thanks in advance.
Run like the wind, straining the limits of machine and man....
2006 Atlas Gray Carrera 4, '81 911SC Black on Tan (SOLD), 2006 Acura RSX Type S, '13 Dodge Durango (wifeys).
Old 10-03-2015, 12:14 PM
Oh Haha's Avatar
Parking brake shoes sticking?
Pacific Blue
Wayne
Old 10-03-2015, 01:01 PM
It's a trap...
I'll check, thanks.
Old 10-03-2015, 01:10 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Ha - The Glass City. Where I grew up. Dad's brother lived in St Clair Shores. It's a tangled web. As a kid drove to Windsor to buy bigger firecrackers. You could still get M-80's in the early 70's. The ones that can remove a chunk of hand from a stupid kid. :-)
Wayne may be on to something. However, I can't picture where load would make brake shoes be quiet.
There are only a handful of parts that spin at wheel RPM.
Even if CV joints were bolted down in a "wonky" manner, there should be plenty of fresh grease to stifle a squeak. However, this is my best guess as to the culprit.
Let's say you bent the backing plate on the brakes. That is a scraping sound if rubbing on rotor. Not a squeak.
Only squeak I ever heard out of the rear end was the right side wheel bearing. Even if the issue, why would load change it?
1981 911SC Targa
Old 10-03-2015, 03:16 PM
It's a trap...
OK, I'll pull the rear wheels and check park break and wheel bearings and CV joints. Thanks.
Old 10-05-2015, 06:19 AM
It's a trap...
My son graduated from UT. He spent a couple of years there. He liked it.
Old 10-06-2015, 12:38 PM
