Question Transmission case sealant question
I'm currently in the process of rebuilding my early 915 mag case transmission. My question is what have people done to ensure a tight "leak-free" seal. Are the standard gasket sufficient without using additional sealant? I've seen several posts using Dow Corning RTV sealant. I can't find that locally. Can I use any standard automotive RTV sealant with the gaskets?
Rick
Old 10-04-2001, 08:23 AM
Early_S_Man's Avatar
I suggest the Loctite 518 product - available at NAPA stores, to prep the paper gaskets.
Warren Hall
1973 911S Targa
1992 Dodge Dakota 5.2 4X4 parts hauler
Old 10-04-2001, 08:36 AM
Irrationally exuberant
ChrisBennet's Avatar
Post
Yeah, what Warren said. The paper gaskets are available seperately for about $1 ea. It is very easy to tear them so you might want to get a few spares.
Old 10-04-2001, 09:24 AM
Talking
Thanks for the help.
Rick
Old 10-04-2001, 10:36 AM
Post
on the thin paper gaskets, any sealant that is going to squeeze out the sides as the parts are torqued together will most likely take the gasket with it. so go sparingly.
Old 10-04-2001, 11:17 AM
Post
JWW,
Thanks for the heads up. Should I try for a thin film on both sides of the gasket as opposed to one that is as thick or thicker than the gasket itself?
Rick
Old 10-04-2001, 11:58 AM
Post
I rub the 518 into the paper gasket before I put the gasket on.
[This message has been edited by ChrisBennet (edited 10-04-2001).]
Old 10-04-2001, 01:11 PM
Post
just a skin coat and let it tack up is your best chance to save the gasket from blowing out.
Old 10-04-2001, 01:42 PM
