MFI cold start squirter hose replacement, help needed
Replacing my MFI cold start squirter hoses and need know if I can just pull the fittings out of the manifold to replace the hoses. I feel some movement in the fittings but not sure if they will come out and if they do, will they go back in and be properly sealed.
Also having a hard time finding 3/16"/4.5mm hose clamps. Only thing other than ear clip clamps is these snapper clamps which are plastic. Has anyone tried these?
Old 10-28-2015, 05:57 PM
Max Sluiter
Flieger's Avatar
Don't touch the fittings.
Old 10-28-2015, 06:16 PM
A slight rotation back and fourth while pulling should bring the fittings out of the manifold.
Old 10-28-2015, 07:35 PM
Usually they are not hard to pull out. But be gentle! These things are old and generally very brittle. If you break one, I don't know where you will find a replacement.
Old 10-28-2015, 07:42 PM
I bought some great fuel proof tubing from McMaster-Carr a while back.....I could look it up if you want.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 10-28-2015, 08:48 PM
So if the fitting comes out, how does it get a good seal when it's put back into the stacks?
Old 10-28-2015, 09:51 PM
I put a little black RTV silicone around fitting.
Old 10-29-2015, 01:59 AM
Those are Oettinger clamps. Just replace them with the new braided hose. If you google Oettinger you can find who sells the special pliers and clamps. Be very careful when removing not to break the plastic stacks.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 10-29-2015, 05:30 AM
They don't need to be sealed, since they are above the throttle plate. Doubtful any air would be drawn in anyway, but if it was there would be no effect. Maybe a dab of Dow silicone grease would be nice, but nothing else.
The braided cloth covered hose is availabel, but you have to do some looking around. Try VW sites. And again, be careful. These old plastic nozzles are fragile.
Old 10-29-2015, 07:08 AM
Those are fuel hoses, so they need to be sealed if you don't want fuel dribbling out with bad consequences.
1991 C2 Turbo
Old 10-29-2015, 10:29 AM
Send a message via Yahoo to mobius911
Pretty sure they are Oetiker clamps, but Google's so good it probably doesn't matter...
Jeff Jensen
1973 911
Old 10-29-2015, 07:21 PM
Tags
mfi , mfi hoses , squirters
