Need help to determine 911SC front shock
Dear forum
I have (also) started a complete suspension rebuild on my '79 911SC, and now looking for new front shock absorbers.
The car is a European coupe.
However, I have a problem determining the right type of shock, any help is appreciated
The struts have no roll pin at bottom, so they are not Bilstein,
The struts are painted black, which makes me think they are Boge type (according to Wayne's article).
From Koni's website, the insert for Boge structs look like this:
http://findershop.koni.com/com/en/popup?img=/img/products/86-1943.jpg
While the insert for Koni struts look like this:
http://findershop.koni.com/com/en/popup?img=/img/products/86-1942.jpg
I have attached a picture of the cars shock, which looks closest to the Koni strut type above - it does not have the small "tap" at the bottom.
My questions to you experts are therefore:
Which strut type do I have, Boge or Koni ?
Which shock would be the right one to buy ?
Unlike the Koni's, the Bilstein gas shocks for Boge struts (34-001134) does not appear to have the small "tap" at the bottom, which makes me even more confused:
Pelican Parts - Product Information: 34-001134-M712
Your help is much appreciated !
/Peter (from Denmark)
Old 11-04-2015, 12:33 AM
Hi forum
Trying again :-)
Has anybody come across a shock absorber like the one on the picture ?
If so, what strut type do you have ? Boge or Koni ?
Thanks !
/Peter
Old 11-04-2015, 10:44 AM
theiceman's Avatar
a better picture of the top might help
looks like a stock Boge insert for an Sc , I replaced mine with Bilstien sport inserts.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 11-04-2015, 11:34 AM
Sure...hope this helps.
The large nut that holds the shock in the strut has been removed on this picture.
Appreciate your help !
/Peter
Old 11-04-2015, 11:40 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Show us the end cap aka GLAND NUT, is it a ID thread or a OD thread? In 1986 ( maybe mid 1985 they went with the Sport Carrera type with ID thread ). PO updated mine with an 1986+ type spindle and housing marked BOGE. Mine was made 1st half of 85.
ID Gland Nut Type
OD Gland Nut Type pre 1986 spindle
'85 Carrera Targa
PCA/POC
Old 11-04-2015, 11:55 AM
Under the radar
Trackrash's Avatar
It looks like the internal tube of a shock insert. In other words the outer tube of the shock is still in the strut?
Show us a picture of your strut.
Gordon
'71 911 Coupe 3,0L outlawed
Old 11-04-2015, 12:14 PM
Thanks, very helpful
The big locking nut clearly goes *into* the strut.
Inspired by the pics, I just cleaned up the strut:
It appears to be a Boge type 911-341-011 (00)
If you look down the strut, it appears empty, except for some sleeve or reinforcement at the bottom 1/3.
If you look closely at this picture, you may be able to see it:
Do you think this is a part of the insert that is stuck down there ?
Again, much appreciated !
/Peter
Old 11-04-2015, 12:32 PM
Correction: Strut type is 911-341-041-00
/Peter
Old 11-04-2015, 12:37 PM
DRACO A5OG's Avatar
Perfect, then you would use this type:
Boge or Bilstein
Far as the insert, I do not recall having one in mine but mine is a 86+
Make sure you put couple of coats of paint on the area you stripped off to avoid rust
'85 Carrera Targa
PCA/POC
Old 11-04-2015, 12:57 PM
Ova Day
msterling's Avatar
So, you have a Boge strut. Just buy inserts designed to fit Boge Struts. Part #34-001127-M512 for Bilstein HD to fit Boge struts. The HD is similar in firmness to the original. Bilstein Sports would be stiffer; part#34-001134-M712. There are other brands to fit the Boge strut too. Boge, KYB, Koni etc. Our host sells these products.
88 Triple Black 911 Carrera Cab, ex Garage Queen
05 BMW E46 M3
21 Tesla Model 3 LR
08 BMW 328xi
15 Ford F150
Old 11-04-2015, 01:09 PM
