Is that an image of the "refurbished DME" with a tie-wrap holding it together or just
a generic image? Hopefully, the circuit boards inside look a lot better.
Dave |
I wondered about the zip tie also. The actual closure tabs were left open, and the zip tie allows easy chip exchange until we get the system dialed in. All the tabs are perfect. Sal went through the interior circuits himself, and says all is spec, including re-soldering potential problem areas and a 28 pin socket upgrade, and factory 89 chip. However we fully plan to open it back up to install Sal's custom chip to go with his new fuel injectors.
Thanks, Dave
Dave McKenzie 1984 Carrera 3.2 1984 928S Automatic 2001 996TT |
Dave, Exactly correct! The reason I zip tie the DME is so that we can quickly change chips during the tuning process. The zip tie holds the cover in place just fine, it risks nothing having it zip tied other than looks. You can't keep bending the tabs, after about the 3 rd time you bend them you will break them.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
Rescuer of old cars
LOL! I have no idea how many times my DME has been apart, but I do know that it only has 2 tabs left. All rest have broken off.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
Ah smart. Yeah mine is missing a few and you can see the metal hairline fracturing on the remaining. |
The tie wrap is such that it can be removed without cutting it. The other way to do this same idea nicely is with a velcro strap available at many hobby shops, totally reusable and easy to use.
Good morning Sal. Do you have a cone type air filter for the AFM, similar to the one on your MAF system?
Thanks, Dave
You can easily use a S&B filter on the AFM but you need to get a decent adapter for the AFM. The adapter needs to transition cleanly and smooth into the square input of the AFM. Something like this:
I'm just showing you this listing as an idea, I'm not sure if that adapter has correct dimensions? You need to measure the factory AFM and find an adapter like this. Then you just size the S&B filter from here: Round with Flange - Universal Filters - Products And use this guide to size it: Round with Flange: Filter Diagram Once you have the adapter and the OD of the round inlet I can assist you with picking a filter.
Hi guys,
I got the WB O2 system installed. Works like a charm. Pretty tedious getting it all neat. For Sal's AFR tests (with no NBO2 sensor signal to DME, open loop): 1. First I set my idle speed with a digital timing light for RPM to 880 with jumper in place. Settled down to a pretty good idle. It does surge by 30 or 40 RPM's though. Idle AFR oscillates between 13.6 and 14.2, with adjustment went to 14.0 to 14.2. 2. Driving the car the AFR's behaved exactly as you described at 3-4000RPM's in 3rd gear. Again 14.2 to 14.6 3. On throttle tip in the AFR drops to 12.6 to 13.0, momentarily, then returns to the 13.8 to 14.0 range. 4. At WOT again the AFR's drop to 12.4 I noticed that if I let off throttle suddenly the AFR goes into the 15-16's momentarily, then returns to 14.0 This stopped with the idle switch disconnected, but the idle went to 1800 RPM. With the idle switch reconnected the car idled in the high 13's until I revved it a little then it settled back to 14.2. I will say there is considerable oscillation about some of these values, in the course of driving. Just for the fun of it, I connected the white wire (simulated NB O2 signal)from the AFR gauge to the O2 sensor lead on the engine harness, and the AFR went to 16-17 and the car stumbled until I quickly disconnected the white wire. The fuel pressure tests were fine: 38 PSI fuel pump on, 31 PSI engine running, 38 PSI with vacuum hose disconnected fro FPR. The car drives quite well. No jerking. Good throttle response, similar to old DME configuration. I'm pretty happy where it stands. I await comments. Thanks, Dave
Dave McKenzie 1984 Carrera 3.2 1984 928S Automatic 2001 996TT Last edited by DaveMcKenz; 11-09-2015 at 11:36 AM.. |
Dave,
Results are as expected. Few things to note. - AEM gauge white wire needs to be setup for NBO2 output, read the docs. The gauge has a switch you need to set to position #4 to simulate a NBO2 signal. The gauge is not setup by default for this. - On decel the DME cuts the injectors till the RPM drops to about 1200RPMs then once below 1200 injectors come back on. This is why the gauge reads lean on decel fuel cut. Other than that I think you are properly setup, drive it a bit so you know how the gauge behaves under different driving conditions.
Brew Master
Sal is a GREAT guy. He has helped me without asking anything in return when I was having some issues. I now have the engine sorted out with a WB02 installed. Once I've taken the time to download the android dyno app that Sal also did a nice write up on, I'm going to make a few runs then I'll be sending the DME in for Sal to work his wonders on.
Hi guys,
I fixed the NB O2 simulated signal. It runs fine but i would have to reset the idle speed, and since we plan to run open loop with the new injectors, I don't plan to do that. The new injectors and chip are the next step. Sal want to bring the car up to snuff first. He has made great progress in drivability with the factory 89 chip over the previous SW chip. He had me order a small chip burner and some EPROM chips. He will soon send me his custom chip and injectors, then any tweaking can be done by emailing files for revised chips until we get it as good as possible. I am sending him some money for the chip and injectors and we will follow through his protocol. Thanks, Dave
Hello.
Just a quick update. I have been trying to get my chip burner and chips to work. I've never touched or seen a chip in my life. I think I have made every mistake, bending pins, not pushing in far enough, but I have not yet had one of my burned chips successfully fire my engine. Sal's burned 89 stock chip works great but none of mine. Sal thinks it may be copy protection problem. I've sent him my burnier and chips to see if he can sort it out. He has my injectors in stock and we should be working on the install in the next week or so. Thanks for watching, Dave
Zip tie or velcro for the dme is brilliant. I started with one broken tab, and each time i have opened it, a tab brakes. Sometimes the simple solutions are the best ones.
I am jumping on the MAF bandwagon this winter. I just need to get off my butt and send out my DME to Sal.
1997 BMW M3 (race car) with S54 engine swap "The Rocket" 1984 Porsche 911 3.4 Carrera 1973 BMW 2002Tii 2016 Ford Focus RS |
Hey John,
You won't be sorry to deal with Sal Good luck, Dave
Here's an update.
Sal checked my chip burner, and the chips it burned were OK when he used his chips, and NG when he used my refurbished, used ,cheap Chinese chips. Who would have guessed. He thinks they had some copy protection problem, even though they were wiped. He sent me a few of his chips. BUT more important, he has shipped me my injectors and his chip which will control them. He has a pretty detailed protocol planned for the install, which I will document when they arrive. Hopefully, more news this weekend. Thanks, Dave
OK guys, I got the chip and injectors today. Sal sent me some good chips, and I was able to burn a functioning chip that started and ran my car. This is important because based on AFR data at different speeds and loads, Sal can modify the chip's BIN file and send me a new file that I can burn onto a chip. That way he can fine tune the system by email. That's pretty neat.
Anyway, tomorrow I will try to install the new injectors and the new chip. Assuming no leaks or other problems I will try to get the car started and running. Unfortunately I am scheduled to get 6" of snow tonight, so I will be inside for a while. We'll see how far I get in the next few days. I will post pics of the process as I go. Dave
Dave McKenzie 1984 Carrera 3.2 1984 928S Automatic 2001 996TT Last edited by DaveMcKenz; 11-20-2015 at 06:30 PM.. |
The chip burning remotly was one feature that sold me (one of many). No mailing my chip across north america (and across border) and back to get a new tune. Sure I need to send my dme off, but that is a one time thing. Proper chip tunig takes a few tries to optomize, and things will be quicker if you start swapping components in the future (which i may do).
I have been out of town for a while and just now saw this thread and I wanted to add my comments on Sal. My '87 3.4 conversion was the first remote install of Sal's MAF, and was performed by my engine builder Greg Johnson at Eurosports Ltd in Denver. The details are in the thread referenced by Sal in this thread (My 3.4 MAF project). I was thoroughly impressed with Sal, my mechanic who worked with Grady Clay for years was very impressed, the car is perfect - but I am unhappy because I miss talking to Sal on a regular basis. Sometimes I find myself hoping that something will go wrong so I will have a reason to call. Alas, the car runs flawlessly and I have but 8000 miles on it since March when the rebuild was completed. I have dealt with both Sal and Steve Wong, and in my personal experience there is no comparison. Sal is a true innovator and a great guy.
Peter 1987 Carrera Coupe 3.4 2003 Boxster S (SOLD) 1986 Carrera Coupe - (SOLD) 1984 944 - (SOLD) |
Thread Tools | |
Rate This Thread | |
