James r long (guest)
Guest
Posts: n/a
69 911t targa How do you get to the brackets that hold the gages in. There is no room under the dash to get to them?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Speedometer Removal - 911 (1965-89) - 930 Turbo (1975-89)
Old 11-11-2015, 08:05 AM
Nick at Pelican Parts's Avatar
it's a tight fit from what I remember. Someone in our community may have a tip for you. I opened a post in our forums. A Pelican community member may be able to answer your question.
- Nick
You can't get to them from under the dash. Open the trunk and shine a light towards the gauges. It may be easier to removed the blower motor assembly first.
JR
Old 11-11-2015, 09:27 AM
From the front trunk. Helps to have small hands, slender arms, and a lot of patience. But its not as bad as it looks. If you get one gauge out, you can access the one next to it through the opening of the one you removed, and so on. Once you've got two, the rest go quickly.
Old 11-11-2015, 09:28 AM
Thanks guys, I figured out that if I remove the dash speaker I could get to the back of the clock. Then through the clock hole I got the speedo. And so on across the dash. Thanks the suggestions. I will try going through the trunk to put them back in.
Old 11-11-2015, 04:07 PM
is removing factory gauges in a 71 the same deal.? I heard that they were just pressed in.? Thx
Old 11-12-2015, 03:34 AM
I can't remember when they changed. It was around 1971, give or take a year. Have a look at the back side of yours with a flashlight. It will be obvious.
JR
Old 11-12-2015, 06:18 AM
Yea if you pull the dash speaker out , just 4 screws, you can see the back of the clock. There are two thumb screws on either side of the gauge. They may be tight but is was able to get mine loose with my fingers.
1969 911t Targa outlaw in progress
1952 356 coupe project
Old 11-12-2015, 08:11 AM
Anyone know if the pre 71 and post 71 gauge gaskets are the same. If the post 71 gaskets is thicker I might order those and just pressure fit mine when I reinstall and leave the brackets off.
Old 11-12-2015, 08:16 AM
