Question How to remove the steering wheel column
Dear Friends
I´m rebuilding this 1976 911 coupe that i recently purchase, and the steering wheel have a huge play one it , about 2 inches up and down
So I would like to know how to remove or access the steering wheel bearing to double check if there something wrong there
Also I would like to know if you guys have any ideia what the problem may be?
Ricardo
Old 11-19-2015, 02:43 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Remove the Horn Fuse or disconnect the battery.
Remove the horn pad
Position the steering wheel.
Unbolt the 27MM nut and remove the wheel.
at this point you should see the bearing and most likely the disintergrated bushing if any.
You will have several options: 928 metal bushing or Mitchel Bushing. Both are pushed into place
'85 Carrera Targa
PCA/POC
Old 11-19-2015, 03:23 PM
83 911 Production Cab #10
JJ 911SC's Avatar
As per D.A.:
Porsche 928 Metal Version Pelican Technical Article: 911 Steering Column Bushing Replacement
Mitch Leland Plastic Version, my next project (bought it in 2010...) http://www.pelicanparts.com/support/install_instructions_PEL-ML-STR.pdf
Who Will Live... Will See
Old 11-19-2015, 03:38 PM
Don't waste your time with the 928 metal sleeve talked about in the technical article
referred to above, it's a bandaid at best! Get the Mitch Leland bushing our host sells.
It's a permanent fix. Check out this loong thread and you will find out all about it.
Mitch Leland's Steering Wheel Bushing
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 11-19-2015, 03:55 PM
JJ 911SC's Avatar
Neither would I, was just for a a general removing instruction.
Here is the link to M.L. installation instruction as posted by
timmy2: http://www.pelicanparts.com/support/install_instructions_PEL-ML-STR.pdf
Old 11-19-2015, 04:07 PM
