ninelevenick's Avatar
You check all electrical connections? Did you check to make sure the green wire by the distributor is connected? Just throwing ideas out there.
Old 11-23-2015, 03:26 PM
Dumb question but have you verified the wires are on the correct cylinders?
1980 911 SC - Black on Red
Chronicles of my '80 SC: http://forums.pelicanparts.com/porsche-911-technical-forum/844949-chronicles-my-80-911-sc-91a0140491.html
Old 11-23-2015, 03:51 PM
Green wire is connected.
Old 11-23-2015, 06:20 PM
The spark plug wires that connect to the spark plugs, will not reach any other destination.. Another words, number two spark plug wire will not reach number 3 cylinder and number one wont reach number two cylinder, same applies for 4,5,and 6.. Its virtually impossible, to cross wires that belong on each spark plug.
On the distributor side, I verified the firing order. Starting with number 1 cylinder which points at the small groove on distributor body, so my rotor then spins ccw... the next would be 6-2-4-3-5 in the firing order . That is all correct.
The vacuum hoses are all connected, there all in the center of the motor, none were in my way.. The only wire I disconnected was the wire that goes to my ac compressor.. I didn't even put the compressor back on the car.
Thanks, I appreciate the help...tomorrow is my last day at work, off for thanksgiving holiday, and I want to drive my car... I honestly feel like an idiot.. But, tend to see life as a learning experience.
Life is good.
Old 11-23-2015, 06:39 PM
Do a compression test, that may indicate your issue. No compression, back to the valves.
Old 11-23-2015, 06:57 PM
wayne robson's Avatar
This graph may help
This may help,found it here somewhere while back
regards Wayne.
Old 11-23-2015, 11:31 PM
I haven't checked my valves without draining the oil, but I'm thinking it's not totally necessary; you may lose a bit but not much. Anyone else had the valve covers off without draining the oil?
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 11-24-2015, 04:36 AM
non-whiner
mreid's Avatar
Yes, just Jack up one side if the car and adjust that side, then the other. You rotate the engine more, but not a big deal.
"Too much is just enough."
Old 11-24-2015, 06:05 AM
Drisump's Avatar
Without actually being there it's impossible to offer much more. My approach has always been if I've been under the hood and something is now amiss vs before the work....the events are connected. It's possible a new problem has occurred out of the blue, but not likely. I can't imagine that the valves are set so tight that they are always open....it would take some effort to get the operation that far wrong. If you can assure us that the leads are all heading to the right place it seems to leave the connections of the leads to either the distributor or plugs. Good luck
Old 11-24-2015, 06:24 AM
Here's something basic you don't seemed to have tried yet: pull the fuel pump fuse (so you don't flood the cylinders), then pull a plug lead off and put in a known good plug. Place plug on engine somewhere and get someone to crank the engine. Check for spark. Repeat for other 5 plug leads. Chances are one or more plugs not firing. If all are firing check for fuel.
1959 Bristol 406 (bought in 1972; sold in 1977)
1966 Porsche 2.0 coupe (bought in 1977; sold 1981)
1978 Porsche SC coupe (bought in 1993)
Old 11-24-2015, 08:26 AM
kuba_kuba's Avatar
What about the wires not seating on the plugs? When I did my valves the first time one of the plug wires wouldn't firmly connect to the plug (I think it was #5). Engine ran as you describe. Did you get a positive "click" when putting the wires back on the plugs?
'88 911 Targa
Old 11-24-2015, 01:46 PM
theiceman's Avatar
show us a crappy cell phone pic of what you think is position number one-six on your distributor .. just for giggles,
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 11-24-2015, 02:02 PM
83 911 Production Cab #10
JJ 911SC's Avatar
If that is the problem it should have been solve back at post 14, maybe he miss it
Who Will Live... Will See
Old 11-24-2015, 03:21 PM
Still here
pmax's Avatar
Perhaps he turned the engine backwards.
Old 11-24-2015, 03:52 PM
I thought about the backwards thing as well.
Old 11-24-2015, 03:55 PM
Talking
Well, I re-grouped and dug back into re-checking and re-adjusting my valves...I had a couple a little too tight..Checked and re-adjusted all of them... Car fired right up and ran good. The valves were the problem.
Now, I have a new problem. Now it sounds like I have a couple a little to loose. I can hear some ticking valve noise... Runs good though.
Looks like I may have to re-adjust again Tighter... what's the repercussions of running them loose, and with a little ticking sound..It drives me crazy.. I think my valves were good before I began to adjust them. The reason I set out to adjust them, was because I didn't know when they were last adjusted.
Life is Good. Thanks guys..the info and help is appreciated.
Old 11-29-2015, 07:10 PM
It's probably OK -- "a little ticking sound" sounds like it's supposed to sound. From what I've read, valves that are little loose are not a problem. Over-tight valves, on the other hand, are -- in retrospect, I think you were wise not to have run the motor until it got hot (tight exhaust valves that do not seat properly can overheat).
So maybe just enjoy the car and take a break. If you're really concerned you can post an audio of the car running.
Old 11-29-2015, 07:49 PM
The ticking noise is very Subtle... not loud. The car runs beautiful, as I reflected.
Old 11-29-2015, 08:39 PM
Leave it alone
Old 11-29-2015, 10:55 PM
Thank goodness for that!
Glad you got there in the end.
A.
"But instinct is something which transcends Knowledge
We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile"
Nikola Tesla
Old 11-30-2015, 12:57 AM
