my sway bar bracket broke off
and I'm looking for someone that is willing to weld mine back on but I'm having a hard time
my question is if i take the sway bar completely off would be a danger to ride around like that until i find someone that can put it back together
Old 11-17-2015, 09:43 PM
Send a message via Skype™ to Porboynz
Well unless you are planning to tackle Nurburgring there will be no problem removing the sway bar. Just avoid 10/10ths cornering until resolved.
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 11-17-2015, 09:47 PM
thanks brother
Old 11-17-2015, 09:50 PM
Both mine tore off recently too so I picked up a set of WEVO from our host and had them welded on by a muffler shop. The moment he saw me coming, he said "sway bar mounts hey... haven't seen too many lately but have done a ton of them in the past."
Wow, I thought he was psychic.
Oh, almost forgot, he only charged me $100 so I gave him a $20 tip...and worth every penny.
By the way, I drove around with both broken sway mounts for two weeks and hardly noticed any difference.
Cheers,
Joe
87 Carrera w/ new sway bar mounts
Old 11-18-2015, 05:38 AM
I am curious. A question to the folks that have had a sway bar mount break. Do you have super sticky tires or oversize tires?
I still have my OEM 15 inch wheels and I have done over 100 autocrosses and several track day DEs on my 85 Carrera. I check my sway bar mounts when I have the car up in the air. No sign of a crack and they look perfect. I just wonder if it is the gummy sticky tires causing higher loads to the suspension than designed or if it is just a fundamental weakness in some brackets.
I just run normal street tires but those are almost all gone for 15 inch wheels. I will be going to bigger wheels and tires just to find some decent rubber. I will keep checking the mounts.
Old 11-18-2015, 06:06 AM
At the time I had just replaced my fuchs with 15" cookies shod with Kumho all season tires when my mounts failed. Even Jay, the muffler guy who did the welding, said the old mounts were not original and had already been replaced before. Seems to be the Achilles heel on these older 911s.
Are you kidding? The Tire Rack still has a ton of choices.
Old 11-18-2015, 06:21 AM
gliding_serpent's Avatar
Wevo all the way. My rebuilder said it is a matter of when, not if.
1997 BMW M3 (race car) with S54 engine swap "The Rocket"
1984 Porsche 911 3.4 Carrera
1973 BMW 2002Tii
2016 Ford Focus RS
Old 11-18-2015, 07:00 AM
wayner's Avatar
For those with pre 74 cars, and BIG sticky tires, also look at supporting the center of the torsion bar tube. They bent in racing so the factory beefed up the design on newer cars.
( think about where the banana arm puts pressure on the tube under cornering and you will see why center supports are a good idea)
Likely not an issue on the street but could be
Details in my thread if you search for it ( see my signature)
SOLD - 914 wide body hot rod
Old 11-18-2015, 07:04 AM
sugarwood's Avatar
Stupid question but, front or rear sway bar?
I think I read it's common for rear sway bar mounts to be weak.
What is the remedy? Rewelding them in with support?
1986 Bosch Icon Wipers coupe.
Old 11-18-2015, 02:59 PM
ganun's Avatar
87 non turbo got the largest to date rear bar, iirc a 21 mm, previously they were 18mm and turbos stayed with the 18mm I know not why. My car had the rear ripped, made it squirrelly when throwing it around a corner, MUCH flatter and controllable with the original 21 mm bar.
Weld it back adapt. Upgrade the mount.
87 911 coupe, GP white, cashmere/black
64 Alfa Romeo Giulia TI - the violin
89 Peugeot 505 Turbowagon-other Pcar
67 912 coupe, white, sold
04 Audi Allroad 2.7T
Old 11-18-2015, 03:09 PM
non-whiner
mreid's Avatar
Rear. Wevo and a couple others make a much beefier solution to replace the stock mounts.
To the OP, if you're near San antonio Texas, come on over. Bring the replacements and I'll grind off the originals and weld on the new ones for you.
"Too much is just enough."
Old 11-18-2015, 03:55 PM
OffCamber00's Avatar
Glen, i was still on street tires at the track when my mounts went. Tires were 255/45-17. I'm attributing the failures to my flat-out driving
Mat P
1988 911 Carrera
Old 11-19-2015, 06:10 AM
Yea, for track tires lots of options. I drive my car on the highway. I plan to drive up into Canada and far NE of the USA next year. Rain happens. I want a normal high performance summer tire with the ability to drive safely in the rain. Not much of any option left.
That is WAY more traction that the factory designed the car for. I have zero proof that is the cause of the sway bar mounts tearing. I just know for a fact that I average 6 to 8 autocrosses every year and over 20 years that is over 120 autocrosses with no isssues whatsoever using 225s on the 15 inch 8 inch factory Fuchs rears.
Old 11-19-2015, 07:03 AM
Totally agree with you on way more traction than originally designed.
I do love my wevo mounts tho No issues w/ sticky tires and big Smart Racing ARBs.
Mat P
1988 911 Carrera
Old 11-19-2015, 07:25 AM
Dublinoh's Avatar
I had to replace and weld in Wevos on my 1987, it had a larger/adjustable rear sway. It is a weak area that will fail when over stressed. Stronger wevos have remained welded. They are way more robust than the original mounts.
Old 11-19-2015, 11:46 AM
Racer
winders's Avatar
Get the JWE bracket (better than Wevo) and never worry about it again!
need sway bar ideas
Available here:
JWE Motorsports | Professional Porsche Race Car Coaching Upgrades Trackside Support Setup and Maintenance
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 11-19-2015, 02:17 PM
This is how my bracket broke. Welded WEVO brackets, no problem since then.
Tires used Toyo RA1 245/45/16
Old 11-19-2015, 02:49 PM
Garage dweller
Ducman's Avatar
Running hard on sticky tires the fronts will fail as well. Enough flexing and the tub metal gets brittle and just cracks out. Elephant sells a front reinforcement plate for tihis very reason. Something to do before you need to.
Don Sjolin
IIIEURO AUTOWERKS
616.874.7932
Old 11-19-2015, 05:43 PM
Banned
Track events at road Atlanta keep that small welding shop in biz. Strategic business location was critical for him. Known atleast Two guys in my short time who used him. He puts cars back on the track for next runs. Doesn't get excited. Just another sway weld. Yawn...
Old 11-19-2015, 05:57 PM
Thank you everyone for the great advice did you have trouble moving the oil lines ??
Old 11-23-2015, 07:41 AM
