AC upgrade that works on 81 sc
HAs anyone used Retroair or Giffiths, or any other system for that matter? I would consider installing if it can use the same dashboard components - don't want a second dash under the first.
thanks
Old 12-10-2015, 05:03 AM
82 SC's Avatar
lots of info out there, do some searches. Does your car already have AC?
1982 SC "Spooky"
1961 VW Single cab truck
1966 VW Deluxe Hard top
Old 12-10-2015, 05:06 AM
82 SC's Avatar
https://griffiths.com/porsche/air-conditioning/911-930/mr-ice-project/ MR Ice project for 1982 model
1982 SC "Spooky"
Old 12-10-2015, 06:27 AM
1983 911SC Chiffon Weiss
mlfox's Avatar
thanks
I purchased and installed this kit:
https://griffiths.com/product/911-kuehl-507-compressor-kit-1-replaces-old-york-2/
It works great.
Regards,
mlfox
Old 12-10-2015, 01:24 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
thanks
Your avatar does not denote your location, which, should be the primary
deciding factor, thus delineating your requirements.
I just finished the A/C conversion from R12 to R134 on our '86 3.2 replacing only
the pump, new barrier lines, dryer, and adding a Renn-Aire Hi flow evaporator.
It is not a job, as I found out, for the un-initiated A/C guy.
If you decide to proceed, pm me with your email, & I'll send you some pics.
Best,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 12-10-2015, 01:55 PM
Banned
That is so true. As Bob K. has pointed out in the various a/c threads, vent temps in the 50s on +/- 80 degree days (achievable with a stock-type system in a good state of tune) works great for areas such as Akron OH, but will not do Jack **** here in TexAss!
Old 12-10-2015, 03:32 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Low 50's with basic charging techniques and R12 filled to factory spec. It was just me doing basic due diligence. Expansion valve, R/D, system clean out,, evap debris removed off of bottom of evap, new oil, vacuum and charge. Later 90's Griffith's Tech Sanden. Pretty stock-type. Did not pull a full "Ronnie" nailing every potential air leak or adding insulation.
Never messed with the thermostat.
I bet high 40's would be possible with some rigor and study.
craigmakes3:
Below is an AC "thread". See post #16. Follow links identified into the value adding posts. It covers a lot of ground.
My AC burns me up --- Help!
If you can stomach it, read a few other posts in this thread and see what wwest, the bead blasting link poster in your thread had to say. You will understand why it was summarized with Eric's (SilberURS6) work in my post.
1981 911SC Targa
Old 12-10-2015, 05:45 PM
Michael T's Avatar
I bought a car that had new hoses, compressor and evaporator. I would get 40 degree vent temps on 75 degree days, but they would increase to 65 degrees on 90 plus days. I just added a third condensor from Zims and had the two hoses fabricated, evacuted and charged. I am interested to see how they do on 90 degree days. I had 29 degree vent temps driving home yesterday.
1987 928 S4 - Black
2014 C4s 991 - Agate Grey
2014 Cayenne - Mahogany metallic
Old 12-10-2015, 06:38 PM
rgoodrich's Avatar
I put in the full Griffeth setup with the two wheel well condensers. I live in the AZ desert where we'll see 120. Up to 105 vent temps can run in the 20's. It only pulls down to 75 degrees when it's 115+. Very happy
Old 12-11-2015, 09:44 AM
Discseven's Avatar
A FULL RONNIE... HAHA!
(See you ref'd my AC saga Bob!)
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 12-11-2015, 05:01 PM
Bob Kontak's Avatar
Ronnie does extremely righteous work.
Have you seen his special van? It's sick and a sleeper. Low 12's in the 1/4. Seat bottoms pivot upwards allowing access to staging cell. 18 years to craft. Envious.
1981 911SC Targa
Old 12-11-2015, 08:46 PM
Banned
Thanks Bob, and you're well on your way to my level of craftsmanship greatness, butt might I suggest that next time, you paint the lettering before drinking your nightly 24-pack?!?!?!
Old 12-11-2015, 09:12 PM
El Duderino
tirwin's Avatar
Nobody goes full Ronnie.
Satisfied Griffith's customer here.
From Griffith's:
- dual wheelwell condenser
- compressor
- barrier hoses
- front condenser
- evaporator
- receiver/drier
Other stuff:
- new front condenser fan blower motor + inline fuse
- new fan speed switch
- rear decklid condenser
- OEM evap fan
Didn't get to drive it too much in the hottest part of the summer this year because I didn't get done until around August and I was out of town a lot for work but I have taken a couple of long road trips since then and it gets super cold. Very nice when you're driving an all-black car.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 12-11-2015, 10:30 PM
Banned
Who's yalls' daddy?!?! Center vents, passenger seat, and headliner . . . upper 90s here in ole' Texass this past summer!!! Getcha suuummmm!!!!
Old 12-11-2015, 11:01 PM
Discseven's Avatar
Who's yalls' daddy?!?! Center vents, evap-twin-turbo ice maker, full bar replaces intercoola, passenger seat with ejection, and no headliner . . . upper 900s here in ole' Texass this past summer!!! Getcha suuummmm drinks on ice!!!!
Nice work on evap-ice maker Ronster albeit curious shape on the ice. Must be an old pipe evap.
Karl ~~~
Old 12-12-2015, 06:56 AM
Bucketlist's Avatar
Retroair
Here is a link to my retroair install which I did about this time last year.
Retroair complete system in my non a/c car
1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters.
Old 12-12-2015, 07:56 AM
Bob Kontak's Avatar
Nice install.
1981 911SC Targa
Old 12-12-2015, 01:41 PM
Mark Wilson
Guest
Posts: n/a
Don't rule our Rennaire. They make some nice kits that cool you off as well. I did parts of their kit of my old 79 and git great vent temps.
Old 12-13-2015, 02:28 PM
More A/C information please....
I guess I didn't really give much of a description of what I am trying to do. i have a 81 sc coupe, with a '79 motor. I stripped out everything related to the non-functioning a/c system, so i am looking for an entire system to replace it. I hope to avoid any additional vents, fans,etc., mounted in or under the existing dashboard. I live in New England, which now gets hot as hell in July and August, and is probably more humid than the Southwestern States.
Old 12-19-2015, 08:18 AM
El Duderino
tirwin's Avatar
Are you saying you didn't keep the parts you stripped out? It would help to understand what needs to be replaced.
If you want better than factory cooling then you need to increase the condensing capacity. There are a few different ways you can do that. Assuming you keep the stock decklid condenser, you can upgrade the front condenser and/or add extra condensers. Griffiths has both a front and rear condenser that mount in the rear driver side wheel well.
Griffiths has everything you need for a complete system,except maybe a rear decklid condenser, if that's what you need. Can't speak for the other companies.
With the '81 you have the tiny slit side vents like my '83. I have an under dash panel so I can't put the extra vent in that connects to the 'bowtie' vent under the dash. I just took the bowtie cover off and it seems fine to me without it.
Talk to Charlie and he can give you a recommendation.
Assume you know his website is Griffiths.com and he goes by Kuehl on Pelican.
Old 12-19-2015, 10:01 PM
