Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Where does this part fit.
![]() ![]() ![]() ^^^^^ WHERE DOES THIS BUSHING/SPACER GO? I FOUND IT ON THE TRUNK FLOOR NEAR THE FUSE PANEL. THANKS IN ADVANCE, GERRY
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Likely a spacer for the rocker panel cover.
Perhaps those were off the car at some point and parts left/lost in trunk? |
+1. Spacer for left side rocker panel
87 911 coupe, GP white, cashmere/black 64 Alfa Romeo Giulia TI - the violin 89 Peugeot 505 Turbowagon-other Pcar 67 912 coupe, white, sold 04 Audi Allroad 2.7T |
#5, as a holdoff for mounting the electrical panel to the LR body panel?
Believe this is the stand-off for the lower mount on the front fuse panel. Takes a long phillips through the standoff into the tub.
RGruppe #180 So many cars.. so little time!! |
Yes.. and there may be two.. one on each end or one in the middle. Cant remember.. duh!
Now for the "endless" search for a P/N........... Thanks, Gerry
Hi Gerry,
Here's a shot of one of mine for some confirmation. Looking down at aft end of the box.
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
spacer
Hi Dan,
Is there only one spacer? Thanks, Gerry
I did a quick look, but it isn't easily evident, and I didn't have my mirror handy.
I thought it'd be simple to see the other end, but it must be behind some of the wiring or the headlamp relay kit. I couldn't even see the screw hardware on the front, unless they are hidden by the fuse blocks and don't know if I'm looking for 2 or 3. I can try to take a more thorough gander tomorrow after work.
Part.
Thanks!
I know yours is an '86 but take a look at the 89 PET.
It shows a phantom spacer, QTY 1 (?) as item #36. PN 911 612 401 00 This same part number is on the '86 PET - not drawn - but on the Parts list with no item (pos) number, just a dash. Also qty 1.
You are correct. Only one required. I don't have the 89 data you have. What is the P/N for the screw that hold the spacer in place? Thanks, Gerry
