86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Where does this part fit.
WHERE DOES THIS BUSHING/SPACER GO?
I FOUND IT ON THE TRUNK FLOOR NEAR THE FUSE PANEL.
THANKS IN ADVANCE,
GERRY
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 11-29-2015, 09:40 AM
Cooper911SC's Avatar
Likely a spacer for the rocker panel cover.
Perhaps those were off the car at some point and parts left/lost in trunk?
Old 11-29-2015, 09:45 AM
ganun's Avatar
+1. Spacer for left side rocker panel
87 911 coupe, GP white, cashmere/black
64 Alfa Romeo Giulia TI - the violin
89 Peugeot 505 Turbowagon-other Pcar
67 912 coupe, white, sold
04 Audi Allroad 2.7T
Old 11-29-2015, 10:29 AM
#5, as a holdoff for mounting the electrical panel to the LR body panel?
Old 11-29-2015, 10:34 AM
onboost's Avatar
Not a spacer for rocker panel, they are half that thickness and a bit rounder. Also not number 5 in diagram for rear electric panel.. those are rubber with vulcanized threaded insert.
Believe this is the stand-off for the lower mount on the front fuse panel. Takes a long phillips through the standoff into the tub.
RGruppe #180
Old 11-29-2015, 11:16 AM
1986 911 Targa.
Only in L.A.:
Old 11-29-2015, 11:23 AM
onboost's Avatar
Yes.. and there may be two.. one on each end or one in the middle. Cant remember.. duh!
RGruppe #180
Old 11-29-2015, 11:27 AM
If there's more than one, I'm missing the rest.
Now for the "endless" search for a P/N...........
Thanks,
Gerry
1986 911 Targa.
Only in L.A.:
Old 11-29-2015, 12:11 PM
steely's Avatar
Hi Gerry,
Here's a shot of one of mine for some confirmation. Looking down at aft end of the box.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 11-29-2015, 02:09 PM
spacer
Hi Dan,
Is there only one spacer?
Thanks,
Gerry
1986 911 Targa.
Only in L.A.:
Old 11-29-2015, 03:25 PM
steely's Avatar
I did a quick look, but it isn't easily evident, and I didn't have my mirror handy.
I thought it'd be simple to see the other end, but it must be behind some of the wiring or the headlamp relay kit. I couldn't even see the screw hardware on the front, unless they are hidden by the fuse blocks and don't know if I'm looking for 2 or 3.
I can try to take a more thorough gander tomorrow after work.
Dan
Venetian Blue
Old 11-29-2015, 04:13 PM
Part.
Thanks!
1986 911 Targa.
Only in L.A.:
Old 11-29-2015, 05:08 PM
steely's Avatar
I know yours is an '86 but take a look at the 89 PET.
It shows a phantom spacer, QTY 1 (?) as item #36.
PN 911 612 401 00
This same part number is on the '86 PET - not drawn - but on the Parts list with no item (pos) number, just a dash. Also qty 1.
Dan
Venetian Blue
Old 11-29-2015, 07:27 PM
PN 911 612 401 00
Steely,
You are correct.
Only one required.
I don't have the 89 data you have.
What is the P/N for the screw that hold the spacer in place?
Thanks,
Gerry
1986 911 Targa.
Only in L.A.:
Old 11-30-2015, 03:07 PM
