TWJ TWJ is offline
TWJ's Avatar
Question for the Engine Gurus
Is this repairable (see pic below) in any way or is this engine toast? I'm sure it also depends on what's going on inside but is the crack repairable?
It's a '70 "E" engine, worth saving?
Thanks!
Old 12-03-2015, 06:58 PM
TWJ TWJ is offline
TWJ's Avatar
Unfortuately I have no idea how this happened. This is a garage find car, an early '66 911 with this (non-matching) '70 "E" engine. I'm trying to figure out if this engine is worth saving...I'm thinking it is but looking to understand the best method.
For the welding...any recommedations on someone who can do this correctly?
Old 12-03-2015, 08:08 PM
Toss it. Since it's not original it's not worth fixing
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 12-03-2015, 08:15 PM
47silver's Avatar
welder
a very good tig welder who knows magnesium should be able to do this weld.
it will need to be taken apart.
check out some videos on welding tips and tricks or mr. tig to get an idea how they weld magnesium.
1975 911S Targa
Silver Anniversary Edition
Old 12-03-2015, 08:19 PM
Diss Member
Quicksilver's Avatar
If it was to be welded and you were able to trust that it was structurally sound it would still need to be machined because it is in no way shape or form going to be a straight crankcase. That is kind of an important detail.
In other words: Toss and replace with good.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 12-03-2015, 08:29 PM
47silver's Avatar
pick up another case if possible but do not throw this one away, someone someday will want it.
1975 911S Targa
Old 12-03-2015, 08:33 PM
Out of curiosity what is the engine#? Ollie's in Havasu City might be able to fix it. They weld repair aluminum Porsche cases anyway. I would guess $1500-$2500 by the time they remachine it so likely not worth it as discussed. You can call and get a ballpark number.
__________________________
'18 Macan S - my turbo Porsche
previous Pcars
'58 356A coupe, '00 Boxster S;'95 993 Polar Silver/Chestnut;'08 Cayman S;'70 911E
Old 12-03-2015, 08:37 PM
TWJ TWJ is offline
TWJ's Avatar
The engine number is: 6201531
Is Ollie's in California?
Old 12-03-2015, 08:52 PM
Home Page Its in Arizona but not far from California
I'm looking for 6201166
previous Pcars
Old 12-04-2015, 06:28 AM
Home of the Whopper
Next time somebody asks if its OK to jack the car up by the sump plate.....
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 12-04-2015, 07:14 AM
I think it was caused by crank flex.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 12-04-2015, 08:34 AM
Straight shooter
Lapkritis's Avatar
Could also see this happening from catching the sump plate on something immovable while the vehicle is in motion.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 12-04-2015, 08:57 AM
Thats what happened here.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 12-04-2015, 09:08 AM
tharbert's Avatar
Originally Posted by 47silver View Post
... do not throw this one away, someone someday will want it.
Unfortunately, this may be true. More and more marginal starting points will become the norm as these engines get older.
BTW, Ollies can indeed weld Mg. They stitched some Mg welds on my case presumably over potential thin spots near #3 piston head studs:
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 12-07-2015, 08:28 AM
jm993rs's Avatar
And is possible sure repair this first pic ??
Old 12-07-2015, 08:55 AM
