How to run wiring from engine compartment into cab?
I'm installing a AEM wideband 02 in my 83 Cab. I have the sensor mounted and the wiring run into the left side of the engine compartment. Is there an easy way to get the wiring into the cab without drilling?
83 RoW Cab.
Send a message if you're here on Oahu.
Old 02-02-2016, 05:02 PM
patz's Avatar
Should be a hole already there, look under the carpet in front of the rear seat. Should be a hole with a rubber grommet for the engine harness.
Old 02-02-2016, 05:13 PM
dos531's Avatar
Your car is earlier so it might be different, but there should be a couple different ways in. I used a hole at the front left of the engine compartment where the harness goes into the cabin.
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC
'12 Gallardo LP-570-4 Performante
Ducati 748R
Old 02-02-2016, 05:22 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Follow the defrost wires on the rear window, that was the hole I used for my Third brake light install
'85 Carrera Targa
PCA/POC
Old 02-02-2016, 05:25 PM
I don't have defrost wires, it's a Cab.
83 RoW Cab.
Old 02-02-2016, 05:44 PM
I don't believe the earlier cars have this access hole. I was looking in that exact location for a while and couldn't figure out how to get it through. With it being cab there's probably a difference in the firewall/rear seat area. I'm guessing a coupe would be easier to get into the passenger compartment.
83 RoW Cab.
Old 02-02-2016, 05:49 PM
patz's Avatar
Joe Bob has an 83 cab, same hole.
Old 02-02-2016, 05:55 PM
Wer bremst verliert
JohnJL's Avatar
Plenty of holes through the transmission tunnel. Reroute the sensor down low and go in through the ~12 holes with grommets there.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 02-02-2016, 06:24 PM
Reiver
Reiver's Avatar
I ran my sensor wire ('83 SC Coupe) thru the central tunnel by attaching a stiff wire (bailing wire) to the end then running the wire thru the opening near the tranny coupling where the electric wire for the tach runs.
You can fish it out/assist it thru the many access points in the tunnel.
I had it come out near the front floorboard then drilled an opening large enough for the plastic connectors on the bottom side of the dash under the clock (where I mounted the guage)...I had just enough unit wire for that to work and it was tight but have had no issues for a few years now.
I think, for a CIS car, an afr gauge is a requirement...huge tuning tool.
De Oppresso Liber
Strength and Honor 5th Legion
Old 02-02-2016, 07:18 PM
Ahh so don't bother going through the engine compartment then.. Looks like the way your describing will be easier..
83 RoW Cab.
Old 02-02-2016, 07:34 PM
I will probably end up doing a version of this..
83 RoW Cab.
Old 02-02-2016, 07:36 PM
Thank you to everyone who helped. I ran it through where the shifter coupling is and all went well. I don't know why I had it in my head that I was going to take it through the engine compartment. I hope this helps someone else in the future.
83 RoW Cab.
Old 02-02-2016, 08:35 PM
Senior Advisor
James Brown's Avatar
i would use a bulkhead connector cannon plug
and a male plug on the cabin side
fluid and flame tight plug
08 Cayenne Turbo
Old 02-02-2016, 08:41 PM
rnln's Avatar
My car, there is a bundle of wires run from front along the left side step through the chassis behind (on the left) the seat, then go up to engine bay from there (behind the rear torsion tube).
Fat butt 911, 1987
Old 02-02-2016, 11:43 PM
