How to run wiring from engine compartment into cab?
I'm installing a AEM wideband 02 in my 83 Cab. I have the sensor mounted and the wiring run into the left side of the engine compartment. Is there an easy way to get the wiring into the cab without drilling?
83 RoW Cab. Send a message if you're here on Oahu.
Should be a hole already there, look under the carpet in front of the rear seat. Should be a hole with a rubber grommet for the engine harness.
Your car is earlier so it might be different, but there should be a couple different ways in. I used a hole at the front left of the engine compartment where the harness goes into the cabin.
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC '12 Gallardo LP-570-4 Performante Ducati 748R |
Member 911 Anonymous
Follow the defrost wires on the rear window, that was the hole I used for my Third brake light install
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
I don't have defrost wires, it's a Cab.
I don't believe the earlier cars have this access hole. I was looking in that exact location for a while and couldn't figure out how to get it through. With it being cab there's probably a difference in the firewall/rear seat area. I'm guessing a coupe would be easier to get into the passenger compartment.
Joe Bob has an 83 cab, same hole.
Wer bremst verliert
Plenty of holes through the transmission tunnel. Reroute the sensor down low and go in through the ~12 holes with grommets there.
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
Reiver
I ran my sensor wire ('83 SC Coupe) thru the central tunnel by attaching a stiff wire (bailing wire) to the end then running the wire thru the opening near the tranny coupling where the electric wire for the tach runs.
You can fish it out/assist it thru the many access points in the tunnel. I had it come out near the front floorboard then drilled an opening large enough for the plastic connectors on the bottom side of the dash under the clock (where I mounted the guage)...I had just enough unit wire for that to work and it was tight but have had no issues for a few years now. I think, for a CIS car, an afr gauge is a requirement...huge tuning tool.
De Oppresso Liber Strength and Honor 5th Legion |
Ahh so don't bother going through the engine compartment then.. Looks like the way your describing will be easier..
Thank you to everyone who helped. I ran it through where the shifter coupling is and all went well. I don't know why I had it in my head that I was going to take it through the engine compartment. I hope this helps someone else in the future.
Senior Advisor
i would use a bulkhead connector cannon plug
![]() and a male plug on the cabin side ![]() fluid and flame tight plug
08 Cayenne Turbo |
My car, there is a bundle of wires run from front along the left side step through the chassis behind (on the left) the seat, then go up to engine bay from there (behind the rear torsion tube).
Fat butt 911, 1987 |
