Mike has all that taken care of. He removes the gallery plugs and you can clean it.
16 Boxster Spyder (sold), 82 911 Wide body/Miami blue/Mike Bruns built 3.6 (sold), 80 911SC Black/tan (sold), 87 930 Turbo 505 slant GP white/black (sold), 95 993 C2 GP white/tan (sold), 82 911SC Hot Rod lightweight Black/black (sold) Last edited by nippy; 06-09-2018 at 04:49 PM.. |
Schleprock
Is that water vapor blasted?
Kevin L '86 Carrera "Larry" |
Media
I use a fine glass bead in a cabinet, all plugs and squirters removed, I have done it for years, not to be atempted without removing everything, this case was getting new squirters and a few oiling mods so it was not alot more labor involved, If you have seen Chris's car this is going in it needed to be done.
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago. |
Hey guys just wanted to give a heads up on Clint from Rebel Racings 934/935 style X strut mount brace (DZUG replica). HOLY COW! Mine is on the way! He has more. I think our sponsor offers them, but if not they should!
Check out https://www.rsrproducts.com/ Going to paint mine Miami Blue over a black carpet kit! Cool thing is, if you choose to keep your spare, the lower left pipe is a removable piece. I myself do not use a spare tire.
16 Boxster Spyder (sold), 82 911 Wide body/Miami blue/Mike Bruns built 3.6 (sold), 80 911SC Black/tan (sold), 87 930 Turbo 505 slant GP white/black (sold), 95 993 C2 GP white/tan (sold), 82 911SC Hot Rod lightweight Black/black (sold) Last edited by nippy; 06-23-2018 at 11:04 AM.. |
Finally the caliper piston drama comes to an end. PMB came through.
16 Boxster Spyder (sold), 82 911 Wide body/Miami blue/Mike Bruns built 3.6 (sold), 80 911SC Black/tan (sold), 87 930 Turbo 505 slant GP white/black (sold), 95 993 C2 GP white/tan (sold), 82 911SC Hot Rod lightweight Black/black (sold) |
Rebel Strut X brace has arrived.
![]() Thinking about painting it Miami blue and doing a black carpet kit in the nose.....
Got the stainless 1 3/4" S-Cargo replica headers in today from William Knight. Thanks buddy!
16 Boxster Spyder (sold), 82 911 Wide body/Miami blue/Mike Bruns built 3.6 (sold), 80 911SC Black/tan (sold), 87 930 Turbo 505 slant GP white/black (sold), 95 993 C2 GP white/tan (sold), 82 911SC Hot Rod lightweight Black/black (sold) Last edited by nippy; 06-23-2018 at 11:00 AM.. |
The strut bar and the stainless headers look like a work of art...
Sent from my iPhone using Tapatalk |
I just went to the entire thread...wow. Where did you get your black RS carpet kit from? I have a charcoal one from AppBiz, but want to send it back for the black one. Also how did you install it to avoid all the bumps on the rear deck, etc.?
Appbiz as well. We grinded everything smooth in the back.
Got the motor stuff back from powder coat! WOW what a difference! Fan shroud, fan, valve covers, timing chain covers and all engine tins.
16 Boxster Spyder (sold), 82 911 Wide body/Miami blue/Mike Bruns built 3.6 (sold), 80 911SC Black/tan (sold), 87 930 Turbo 505 slant GP white/black (sold), 95 993 C2 GP white/tan (sold), 82 911SC Hot Rod lightweight Black/black (sold) Last edited by nippy; 06-23-2018 at 11:05 AM.. |
The rear suspension made it today. Again big thanks to Clint at Rebel Racing!
RSR S racing adjustable spring plate set RSR bushing set Tarett rear sway bar (WEVO sway bar mounts are welded/mounted in the car and ready) Hollow torsion bars (30s)
16 Boxster Spyder (sold), 82 911 Wide body/Miami blue/Mike Bruns built 3.6 (sold), 80 911SC Black/tan (sold), 87 930 Turbo 505 slant GP white/black (sold), 95 993 C2 GP white/tan (sold), 82 911SC Hot Rod lightweight Black/black (sold) Last edited by nippy; 06-26-2018 at 08:53 PM.. |
Ran out of picture space...anyway....
Rebel rear sealed monoballs Last but not least new rear wheel bearings
Can I ask a silly question about that sweet-looking strut brace?
All the pieces and parts look like they bolt together beautifully and create a nice rigid frame, but how does it accommodate front strut alignment changes? Thanks, Tom
'74 911 Red Sunroof Coupe, 3.6L, etc... '76 912 Yellow SPEC 911/911CUP |
subd for later
81 SC 3.8 Conversion 2017 Macan S INSTAGRAM @tail_spinz |
From Rebel This brace does not require any chassis modifications and is completely reversible, designed to be incredibly rigid offering the highest levels of chassis strengthening that can be offered by a chassis brace short of a full cage. With three active points of attachment at each corner to the chassis, each individual area can support incredible loads, and when combined this brace will ensure no chassis flex from the corners, tower collapse nor tower expansion (camber change mid corner). Designed and executed the "X" brace locks the strut towers together at all 3 points per side of mounting. The resulting product is a super rigid structure that is not in need of additional bars going to the bottom of the strut tower. The cross bar is tied into the "X" sharing torsional load down to each corner of the front of the chassis allowing the forces that would normally twist the chassis to be spread over a large but very stiff area of triangulation using each side of the chassis to in effect brace against itself. Just as was found at IMSA & LeMans, our chassis brace gives you what you need in a lightweight package - everything you need, nothing you don't.
Schleprock
I think what Tom is asking, is how does the brace allow moving the strut tops to adjust alignment settings if the brace itself doesn't have any adjustability to it at the strut mounts? The bars don't have any threaded rod ends and none of the holes in the bar tabs or brackets are slotted.
Here are some pics of it installed along with the Rennline monoballs. red brake calipers looking good. Shes hanging with some good company
16 Boxster Spyder (sold), 82 911 Wide body/Miami blue/Mike Bruns built 3.6 (sold), 80 911SC Black/tan (sold), 87 930 Turbo 505 slant GP white/black (sold), 95 993 C2 GP white/tan (sold), 82 911SC Hot Rod lightweight Black/black (sold) Last edited by nippy; 06-27-2018 at 02:43 PM.. |
scumbag
so i've just wrecked my entire afternoon here at work reading this whole thread and not doing anything productive (as far as my boss would be concerned).
tremendous build. my only concern is that it seems to me that you've spent the strong majority of the time with this car in some state of disassembly and very seldom get to drive it. i hope once the new engine is complete that you will properly romp on this car every day until your last. i'm only 6 months into (and have never driven) my build. very inspiring work. but all i think about is driving it. hats off to you for voluntarily taking it off the road so much to execute your goals/dreams.
My first Porsche - http://forums.pelicanparts.com/porsche-911-technical-forum/989493-my-low-budget-dream-car-build.html AchtungKraft #009 - IG: @doktor_b |
