Not what my bank account thinks...LOL. Anyway, got a new replacement wheel from Fikse. My old one was a taco. Took some pics while the wheel was off. New wheel http://forums.pelicanparts.com/uploa...1542042902.JPG taco wheel http://forums.pelicanparts.com/uploa...1542042902.JPG New suspension goodies..... http://forums.pelicanparts.com/uploa...1542042902.JPG http://forums.pelicanparts.com/uploa...1542042902.JPG http://forums.pelicanparts.com/uploa...1542042902.JPG |
I LOVE WHEN I GET A TEXT FROM MIKE BRUNS! SmileWavy
checking the GT3 oil pump fit and the backlash on the intermediate shaft to crank gears, machined the piston oil squirter holes and they are ready to install after the final cleaning on the case. http://forums.pelicanparts.com/uploa...1542153622.JPG http://forums.pelicanparts.com/uploa...1542153622.JPG http://forums.pelicanparts.com/uploa...1542153622.JPG http://forums.pelicanparts.com/uploa...1542153622.JPG http://forums.pelicanparts.com/uploa...1542153622.JPG http://forums.pelicanparts.com/uploa...1542153622.JPG |
Beautiful!
Switched to the classic lenses today. May go back to no letters on the tires and just go the classic route...
One classic lense and one bug eye for comparison http://forums.pelicanparts.com/uploa...1543009186.JPG http://forums.pelicanparts.com/uploa...1543009186.JPG http://forums.pelicanparts.com/uploa...1543009186.JPG http://forums.pelicanparts.com/uploa...1543009186.JPG |
Did I see your car on ebay and that it sold?
Nope car didn't sell. I threw it out there after the initial build to see if I could sell it and perhaps build another twin. Didn't work so just kept it and now going to just enjoy it. The engine in this car is going to be a monster.
The heads are back from Bill at Xtreme Cylinder Heads. These are factory SC heads from my motor.
From Mike Bruns regarding what has been done to the heads: Larger ports with proper shape and larger valves along with a precision valve angle and seat angles to help flow in and out.Working together all this improves the ability to make power. With CNC porting everything is exactly the same where before being done by hand was very time consuming and close but not perfect, even the valve job is done with CNC machines You also have twin plug using 12mm threads to reduce the chamber volume increase (which effects compression ratio) look at the picture of the original plug hole vs the new hole, we also reduced the valve stem size from 9mm to 8mm to reduce weight and increase air flow, the injector notch was welded up before the port work too. http://forums.pelicanparts.com/uploa...1543848093.JPG http://forums.pelicanparts.com/uploa...1543848093.JPG http://forums.pelicanparts.com/uploa...1543848093.JPG http://forums.pelicanparts.com/uploa...1543848093.JPG http://forums.pelicanparts.com/uploa...1543848093.JPG http://forums.pelicanparts.com/uploa...1543848093.JPG |
Beautiful! Then you have to bolt it up an put gas and fire in there?
Forgot you were waiting for heads - Bill at Extreme does great work
Got a new rig to pull the 911 once I get the featherlite trailer. Otherwise that bed holds a ****load of wheels, ask me how I know!
2017 Toyota Tundra double cab long bed (8 ft) 5.7L. V8 380HP http://forums.pelicanparts.com/uploa...1544288732.JPG http://forums.pelicanparts.com/uploa...1544288732.JPG http://forums.pelicanparts.com/uploa...1544288732.JPG http://forums.pelicanparts.com/uploa...1544288732.JPG |
MSD ignition goodies came in today....(2) black MSD-6AL digital ignition with rev limiter, (2) blaster coils high vibration and 2 universal clamps.
http://forums.pelicanparts.com/uploa...1544903176.JPG http://forums.pelicanparts.com/uploa...1544903176.JPG http://forums.pelicanparts.com/uploa...1544903176.JPG http://forums.pelicanparts.com/uploa...1544903176.JPG http://forums.pelicanparts.com/uploa...1544903176.JPG http://forums.pelicanparts.com/uploa...1544903176.JPG http://forums.pelicanparts.com/uploa...1544903176.JPG http://forums.pelicanparts.com/uploa...1544903176.JPG |
Mike Bruns says the crank and rods are installed for the final time. The case goes together next! SmileWavy Trying to have her ready for the Rolex but its going to be close.
http://forums.pelicanparts.com/uploa...1545227881.JPG http://forums.pelicanparts.com/uploa...1545227881.JPG http://forums.pelicanparts.com/uploa...1545227881.JPG |
Sweet!!
The case is together. Things are moving along! Mike Bruns has been busy!SmileWavy
http://forums.pelicanparts.com/uploa...1545267662.JPG http://forums.pelicanparts.com/uploa...1545267662.JPG http://forums.pelicanparts.com/uploa...1545267662.JPG http://forums.pelicanparts.com/uploa...1545267662.JPG http://forums.pelicanparts.com/uploa...1545267662.JPG http://forums.pelicanparts.com/uploa...1545267662.JPG http://forums.pelicanparts.com/uploa...1545267662.JPG http://forums.pelicanparts.com/uploa...1545267662.JPG |
Can't say enough good things about Mike Bruns. He helped me build my 3.0L Twin Plug to bullet proof standards. With Paul Abbotts's help with my weber's it's more fun than you can imagine. Of course the car is the other half. Lot's of tweeking over the years and it's 9:1 power to weight. But I can say the engine is half the car. You want reliability, and you want something that has some low end torque but still high end horsepower, which my cam grinder built for me. You don't want something you have to turn 5500+ to feel that push into the seat back, but still you want that push to last a little before you have to shift.
Ok running off at the mouth. Happy Holidays to all including Mike Bruns and Paul Abbott. |
| All times are GMT -8. The time now is 08:13 AM. |
