So tranny time...bearings loose and needs some machine work. So going out to CMS in California to have the work done. Going to need the billet side plate and new style bearing retainer also. Just want to have it strong enough and fresh to deal with the HP/TQ of the new engine..
Motor is in good company in Mikes shop.
16 Boxster Spyder (sold), 82 911 Wide body/Miami blue/Mike Bruns built 3.6 (sold), 80 911SC Black/tan (sold), 87 930 Turbo 505 slant GP white/black (sold), 95 993 C2 GP white/tan (sold), 82 911SC Hot Rod lightweight Black/black (sold) Last edited by nippy; 01-30-2019 at 03:09 PM.. |
Mike doing his magic on the tranny now, getting it cleaned up.
16 Boxster Spyder (sold), 82 911 Wide body/Miami blue/Mike Bruns built 3.6 (sold), 80 911SC Black/tan (sold), 87 930 Turbo 505 slant GP white/black (sold), 95 993 C2 GP white/tan (sold), 82 911SC Hot Rod lightweight Black/black (sold) |
I am curious as to what fraction of a gram? should internal engine parts be weighed to when reasonabley balancing piston pins, pistons, connecting rods, ect as I am looking to buy a good scale? (I am not questioning anyone or anything here in this awesome build thread just hoping the experts on this thread will post their suggestions/opinions...)
Pm’ing me is fine if preferred or post here... Thx in advance for any and all input...” Now back to this incredible build...!!
I live for 911 tweaks... |
Best move was getting rid of the woman!!
Hello everyone, my name is Maymac, nice to meet you |
Now that's clean.....
![]() ![]() ![]() ![]() Thanks Mike! Heading to CMS for bell housing bore repair, gear housing bore repair and new bearings installed. Wil be adding the WEVO billet side cover and new style bearing retaining plate along with new internal parts where needed.
16 Boxster Spyder (sold), 82 911 Wide body/Miami blue/Mike Bruns built 3.6 (sold), 80 911SC Black/tan (sold), 87 930 Turbo 505 slant GP white/black (sold), 95 993 C2 GP white/tan (sold), 82 911SC Hot Rod lightweight Black/black (sold) Last edited by nippy; 02-01-2019 at 02:50 PM.. |
Ktl i have the dyno numbers on the m&k on a few motors... There a nice product and good guys, i do not think the muffler is designed for higher performance applications. It looks great and has good workmanship. The m&k is designed for stock application and i believe they represent the product this way.. Therefore we give them credit. I have clients who i send to m&k when there not trying to make big hp gains. I seriously expect my design to beat the cup muffler on the same headers, i have another design for ssi. I have engineered these mufflers for max hp without drone or too loud for the street. I am not selling these, i give my designs away to help people on the pelican site. I am thankful we can help each other, thanks wayne.
For an example the wrong muffler on a mild street 3 liter can hurt you by 22 hp at the rear wheels. My email is knightrace@mac.com if anyone has cam questions in relationship to exhaust i am glad to help. Thanks, william knight |
I'm very interested to know more about the engine configuration if it's not proprietary for the builder...
1) I saw you were using Pauter rods with the GT3 crank and wondered what rod length was chosen for this engine build. 127.8mm (SC), 127.0mm (Carrera), or other custom length? 2) What cams did you use? 3) You got some big power at the upper end as the dyno printouts show but since this is primarily a street car how does the mid-range power look? |
16 Boxster Spyder (sold), 82 911 Wide body/Miami blue/Mike Bruns built 3.6 (sold), 80 911SC Black/tan (sold), 87 930 Turbo 505 slant GP white/black (sold), 95 993 C2 GP white/tan (sold), 82 911SC Hot Rod lightweight Black/black (sold) Last edited by nippy; 02-04-2019 at 08:15 AM.. |
Engine specs
The engine dyno begins the data collection at wide open throttle and is held at the set RPM until you press go, so at the lower range WOT is tough to do even for a stock CIS engine at 3000 RPM, The rod length varies depending on where the pin location is in the pistons I use for a given build, typically all the parts are a custom design including the cams, which are ground by Dema Elgin, similar to a GE40 with a different lobe separation.
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago. |
Inline fuel filter is in
16 Boxster Spyder (sold), 82 911 Wide body/Miami blue/Mike Bruns built 3.6 (sold), 80 911SC Black/tan (sold), 87 930 Turbo 505 slant GP white/black (sold), 95 993 C2 GP white/tan (sold), 82 911SC Hot Rod lightweight Black/black (sold) Last edited by nippy; 02-05-2019 at 06:57 AM.. |
Registered Minimalist
Nice! Looks great!
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
FWIW - I had issues with that same filter. Think it’s like 25 micron. I went with a Fuelab 818 inline filter. -6an, fits in same spot (a bit larger/longer). It’s 10 micron cellulose replaceable element.
Also had issues with a good seal on my rain hats, but that’s another story. Todd
'81 SC |
scumbag
The layout of the fuel lines looks very nice. It will really look well put together when the engine is installed.
My first Porsche - http://forums.pelicanparts.com/porsche-911-technical-forum/989493-my-low-budget-dream-car-build.html AchtungKraft #009 - IG: @doktor_b |
Will be running ethanol free 93 octane
I think E85 fuels are the issue with cellulose. I’m fortunate enough to be able to get ethanol free gas. Fuelab makes a few different elements for the filter, just happens to come with a paper one. The Russel one (and similar) is just a mesh disc, not a lot of surface area there.
Todd Todd
'81 SC |
Ill check out the Fuel lab..
Schleprock
How small of a micron rating do we need for the carbs? Between 10 and 40 microns is typically considered OK for the filter between the pump and the carbs.
I used an Earl's sintered metal filter for my carb'd engine. It's a similar sized/shaped body as the one pictured by nippy. Earl's makes it in black and the busy looking foil sticker easily peels off if you get to much fuel on it (ask me how I know...) Just make sure you respect the flow direction. If you lose the sticker and don't know the direction you can always open the filter to see the element. Flow goes from outside to inside because the most surface area for filtration is on the outside of the element https://www.holley.com/products/plumbing_an_fittings_and_hose/fuel_system_components/fuel_filters/parts/AT230106ERL HEre's the filter element https://www.holley.com/products/plumbing_an_fittings_and_hose/fuel_system_components/fuel_filters/parts/230107ERL
Kevin L '86 Carrera "Larry" |
Mike Bruns wanted it to be rated at Fuel injection quality and I asked my guys to grab one. That's what they got.
Ok that's why I love these forums. Thanks toddu for the heads up. I ran it by Mike Bruns and he agreed the other didn't have allot of surface area. So I grabbed the
Fuelab 81801-1. Summit had them and free ship. ![]() Add it to the pile....JESUS I heard the slope was slippery but not vertical.
16 Boxster Spyder (sold), 82 911 Wide body/Miami blue/Mike Bruns built 3.6 (sold), 80 911SC Black/tan (sold), 87 930 Turbo 505 slant GP white/black (sold), 95 993 C2 GP white/tan (sold), 82 911SC Hot Rod lightweight Black/black (sold) Last edited by nippy; 02-05-2019 at 11:22 AM.. |
Fuellab is much better, Part of the problem on the PMO carbs for the first few months is the ethanol in todays fuels eats debris off of the polymer floats and that gets into the carbs. seems to stop after a little while. If you use fuel without ethanol not a problem. If you drive the car often not a problem. If you store it for winter just put race fuel like 100 octane unleaded in it. Todays feel from the pump has a really short shelf life in a vented system like an older 911. William Knight
