Mikes wrapping things up. Black plug wires being installed.
http://forums.pelicanparts.com/uploa...1558396766.JPG |
Hey Nippy
Tell Mike Bruns hello. He helped me build my twin plug 3.0L 10 years ago. The darned engine runs perfect. Idles smooth and then screams like a cat when you put your foot down. I asked Mike for a build that I could run the daylights out of and then drive home and just change the oil and adjust the valves once a year. Got what I asked for. Your will be happy with his work for sure. |
the plugs of em wires look very "solid", not like them BERU/NGK ones? What brand are these? Manufacturer code/partnumber please.
Plug Wires
The ends are Magnacore (5 pieces per end) the wires are a Moroso blue max 8mm spiral core that we have used for years, the wires are custom built as needed, you can buy the wire in 50' to 100' rolls in several colors, black,blue,red and cut to length, to do a typical twin plug 911 it takes a bit over 50' including coil wires depending on coil locations.
Mike Bruns Kent, glad to hear you are well ! |
Wires ran, Mike Bruns is finishing the deal, SO EXCITED! Dyno Saturday for carb tune!
http://forums.pelicanparts.com/uploa...1558491001.JPG http://forums.pelicanparts.com/uploa...1558491001.JPG http://forums.pelicanparts.com/uploa...1558491001.JPG http://forums.pelicanparts.com/uploa...1558491001.JPG http://forums.pelicanparts.com/uploa...1558491001.JPG http://forums.pelicanparts.com/uploa...1558491001.JPG http://forums.pelicanparts.com/uploa...1558491001.JPG |
So you settled on the Dynomax 17231 muffler?
Exciting !
Please post a dyno video if that is possible. |
I remember when Mike ran my engine on the dyno. I built the engine at home in my garage so I was a little nervous. He sent me to the gas station to get some gas. When I got back the engine was screaming on the dyno. What a relief. I was so nervous that I might have done something wrong.
However here it is when Mike was running power pulls a few months back. This is 50MM PMOs, open race headers and a GT3 cup muffler 381.8HP/303.8TQ <iframe width="560" height="315" src="https://www.youtube.com/embed/AE4lUoos1-s" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe> This is 50MM PMOs, S cargo replica stainless headers and a dynomax muffler (the set up were going with) 374.2HP/297.1TQ <iframe width="560" height="315" src="https://www.youtube.com/embed/0lRYDZcFFyU" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe> |
Here ya go
Dyno vid here <iframe width="560" height="315" src="https://www.youtube.com/embed/VNjLjRUQ_sA" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe> Results http://forums.pelicanparts.com/uploa...1558836220.JPG |
Wow that makes tons of torque.
Mike Bruns getting the tranny ready. The pinion depth is set.
SmileWavy http://forums.pelicanparts.com/uploa...1559225201.JPG http://forums.pelicanparts.com/uploa...1559225201.JPG |
Nippy, thanks for the dyno vids.
That muffler sounds really good, i think i will try one of those on my car. |
Mike is THE Man - your car will be a beast! Looking forward to seeing it
I pick up the engine and tranny Friday if all goes well. So the car will be on the road again very shortly. :D
Nice new ground strap Mike found in his stash! http://forums.pelicanparts.com/uploa...1559700050.JPG Guard LSD installed and ready http://forums.pelicanparts.com/uploa...1559700050.JPG The diff is all set and the final adjustments are done on the gear stacks and shift forks, the box is ready to go together for good! http://forums.pelicanparts.com/uploa...1559700050.JPG http://forums.pelicanparts.com/uploa...1559700050.JPG Mike said he's never seen a 915 tranny that has these #s intact, usually they get ground off over the years from being dragged around on concrete http://forums.pelicanparts.com/uploa...1559700050.JPG |
Looking great as usual. Mike is top notch.
Noticed one thing i'm sure Mike already took care of http://forums.pelicanparts.com/uploa...1559741034.jpg |
Yep Mike has it covered as usual!
| All times are GMT -8. The time now is 12:11 AM. |
