You're going to run out of gear and he will not.
New oil cap, mine was looking a bit rough. The engine bay should be pretty once the motor is back in there. Also got new differential bolts (12). The Guard LSD uses 928 length bolts, hence the 928 part #.
http://forums.pelicanparts.com/uploa...1554841962.JPG http://forums.pelicanparts.com/uploa...1554841962.JPG http://forums.pelicanparts.com/uploa...1554841962.JPG http://forums.pelicanparts.com/uploa...1554841962.JPG http://forums.pelicanparts.com/uploa...1554841962.JPG http://forums.pelicanparts.com/uploa...1554841962.JPG http://forums.pelicanparts.com/uploa...1554841962.JPG |
Just remember. Years ago I talked to a tire shop. He said he made more money than he ever did in the shop since they came out with the low profile tires. Why? The low profile tires bent the rims in pot holes and that meant a wheel replacement. Ha Ha.
he is 4.5 lb per hp
your car is 6.4 lbs per hp so his power to weight is roughly 30% better. |
power to weight ratio is a curious thing.
my brother has ZL1 camaro. 4000 lbs. and 650 HP. i have a 2000 lb. 914 with close to 300 HP. modern nannies aside, similar power to weight ratios, vastly different driving experiences... |
Garage goals fellas!
Thank you to my buddy who likes to remain behind the scene...his cars speak for themselves and the "illness". Im very sick as well, just don't have the funds. GT2RS 700HP/553TQ 3241 lbs Ferrari 812 788HP/529TQ 3593 lbs Porsche CGT 605HP/TQ435 3043 lbs WINNER TO ME???? The one with 3 pedals! http://forums.pelicanparts.com/uploa...1554958148.JPG |
Spinnin' ain't Winnin' :D |
The car had so much dust on it, I had to wash it. I cant wait to get back behind the wheel!
http://forums.pelicanparts.com/uploa...1555549656.JPG http://forums.pelicanparts.com/uploa...1555549656.JPG |
Missing “loose” 2nd gear and the 1-2 shift sleeve????
:D |
Yep Mike found some issues with 2nd gear and had to take apart and replace |
Can you notice the difference in the LSD?
Havent got it back yet
It’s still in mock up stages, there’s a gear noise turning it through and in the process of elimination, the second gear set was the problem, I am guessing it ran a long time with the bearings loose and now that it’s tight center to center it wasn’t happy
Mike Bruns |
Just giving nippy a hard time. I suspected it was in prefinal assembly process.
Great observation from Mike on the gear noise during assembly. That's not a talent you're going to find very often. Mike will also set you up with a nice 2nd gear for sure. He sold me a very nice 18:33 2nd gear set for my needs awhile back. |
A lot of money spent in these photos.
Swchweet build porn for sure.. car has come a long way this time around!
| All times are GMT -8. The time now is 10:22 PM. |
