rear bumper fitted w/tow hook
http://forums.pelicanparts.com/uploa...1456175204.jpg http://forums.pelicanparts.com/uploa...1456175315.jpg Front bumper oil cooler cut out http://forums.pelicanparts.com/uploa...1456175270.jpg 62 twin grill sitting off to the side http://forums.pelicanparts.com/uploa...1456175362.jpg |
Factory Porsche Fuchs wheel caps came in today. These fit the 17" Fikse/Fuchs.http://forums.pelicanparts.com/uploa...1456327947.jpg
http://forums.pelicanparts.com/uploa...1456327962.jpg |
Love the build. Glade to see someone being creative in my back yard. What's up with the oil lines? Just dropped for easy access or replacing???
ER front mounted oil cooler kit with finned lines, setrab cooler, air deflection panel, new thermostat, high clearance lines, crossover pipe and all install parts showed up today. Well needed as it gets hot here in Florida, especially down at Sebring when your running full out!
http://forums.pelicanparts.com/uploa...1458053062.jpg http://forums.pelicanparts.com/uploa...1458053087.jpg http://forums.pelicanparts.com/uploa...1458053101.jpg http://forums.pelicanparts.com/uploa...1458053155.jpg Also received the Rothsport lightweight fiberglass lamp buckets, supposedly saves around 6.5 lbs off the rear end. They are very very light. They accept the factory rubber seals and lenses. http://forums.pelicanparts.com/uploa...1458053229.jpg http://forums.pelicanparts.com/uploa...1458053259.jpg http://forums.pelicanparts.com/uploa...1458053286.jpg |
The above oil cooling kit diagram
http://forums.pelicanparts.com/uploa...1458055284.jpg |
Last but not least, Wevo classic shifter with precision shift joint and light weight shift knob. The car should go back together rather quickly now I'm hoping. SmileWavy
http://forums.pelicanparts.com/uploa...1458164228.jpg http://forums.pelicanparts.com/uploa...1458164247.jpg http://forums.pelicanparts.com/uploa...1458164264.jpg |
Nippy, where did you find these things? ROthsport doesn't list them on their website that I can find. I need a set!
How stout are the FG rear housings since they tend to get blasted by rocks thrown off the tires? Anybody else own these?
Looking good Nippy! But that carbon fiber dash is awful, LOL.
fenders in primer, fitting the getty hood. Sunroof welded smoothed and primered
. http://forums.pelicanparts.com/uploa...1458328113.jpg http://forums.pelicanparts.com/uploa...1458328134.jpg http://forums.pelicanparts.com/uploa...1458328149.jpg |
Nippy. I see you purchased a new thermostat with the oil lines. Do these go bad? Or is it just preventitive maintenance?
I have the wevo classic shifter also, and love it. I also have the same center oil cooler and mounting brackets. Very nice solution. Great build. You have me thinking about my sunroof.
If anybody needs 911 tail light housings...
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/906737-2-tail-light-housings-911sc.html http://forums.pelicanparts.com/uploa...1458486963.jpg |
WEVO motor/tranny mounts came in
http://forums.pelicanparts.com/uploa...1458843072.jpg http://forums.pelicanparts.com/uploa...1458843089.jpg |
| All times are GMT -8. The time now is 11:23 PM. |
