Testing a differential
So today I turned the rear wheels as the car was raised from the ground, and noticed the wheel on the other side doesn't turn the other direction (so no LSD). However, I thought that no LSD means the wheels will turn in the same direction? My 'other' wheel doesn't move at all...
Member 911 Anonymous
Nope, that is normal for a Standard differential. When you peel out from stand still you will notice only one set of rubber tracks.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Cheers DRACO A5OG!
