universeman's Avatar
Smoke from dash - what should I inspect/replace?
Had a flat today. While refilling the space saver spare with the 30-year old compressor :-/ - no option at the time - I got smoke pouring from the dash. Cut battery (yay quick disconnect - may have saved the car) until smoke stopped, and limped home.
Now I have no power to the 12v cigarette lighter and no ashtray light. These of course are not critical items, but I'm worried about wiring damage and what else might happen. Any advice on how to assess the damage from anyone who's been through it?
Jason - Austin, TX
82 911 SC targa (gone, but not forgotten)
92 968 coupe
Old 01-07-2016, 01:29 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Oh snap.
You will need to remove the air intake screen, tube & fresh air components from the frunk to gain access to the cigarette lighter wire. Most likely that has burnt/melted.
The ashtray light is part of the gauge and instrument light system (black with blue wire cluster). Hopefully it is just a blown bulb. Do the gauge lights work? ( good idea to install a fuse here )
What concerns me is that the fuse did not blow first. Check to make sure the circuit for the cigarette has the correct fuse. PO may have installed too large of a fuse which would result in melting or burning of the wire. As a mater of good practice, make sure all fuses are correct sizes to avoid this type of event in the future.
Jim
P.S. did you keep the car on while you were using the pump or just battery power?
'85 Carrera Targa
PCA/POC
Old 01-07-2016, 01:47 PM
Unregistered
sammyg2's Avatar
Inspect the name tag on the car and make sure it doesn't say JAGUAR
Sorry, couldn't help myself.
Old 01-07-2016, 01:49 PM
Sammyg2, it's a Porsche (I just checked.) However I did just have the entire car re-wired by a British gentleman named Oliver who drives an XKE and wears tweed.
Update: the ashtray light works, as does instrument panel. The 12v outlet shows power when I use a signal light, but it's weak. I think the wire is burnt.
I couldn't keep the car running because (here's more) the handbrake lever is out of the car right now while I diagnose the brake light issue. No way to keep it running in neutral without it rolling away. (May start carrying wheel blocks.) Curious what difference it might have made?
Cigarette has a 25A fuse. As luck would have it, the super-fancy fuse panel upgrade from the UK guys who make CDI+ is on a FedEx truck on its way to my house as I type this. Will probably be installing it tonight.
Jason - Austin, TX
92 968 coupe
Old 01-07-2016, 02:50 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Dash light.
Here's a few dash lights ideas.
The A/C evaporator.
And, if you don't want one of these.
Add one of these....
Fusing was not one of Porsche's finest hours.......At least on our 3.2.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 01-07-2016, 02:53 PM
Charles Freeborn's Avatar
Oh boy, I hope you don't have what I've been chasing for some time now....PO did a crappy alarm and stereo install and fried wiring inside one of the harnesses. It stayed hot long enough to melt through adjoining wiring. Had to cut open the harness, replace damaged wiring and re-wrap the affected areas. Still have a gremlin in there somewhere that gives goofy turn indicator lights in tach... Major PITA... Wishing you better luck than I had...
I think wiring up a dedicated 12v fused outlet in the frunk for purpose of tire inflator is a swell idea.
Bone stock 1974 911S Targa.
1972 914/4 Race Car
Old 01-07-2016, 03:55 PM
Thanks for the fuse ideas
I'm hoping I don't have gremlins from this...so far the only casualty is my 12v cigarette socket...
Goofy turn indicators in tach could be from turn signal housings not making good contact/ground - I already chased that one down in mine
Jason - Austin, TX
92 968 coupe
Old 01-07-2016, 04:46 PM
ted ted is offline
likes to left foot brake.
ted's Avatar
Be very careful.
You may have one short, one wire that is glowing red hot melting and smoking off the wire insulation.
After that the glowing red hot wire will melt through the insulation of any wires it touches creating a massive short and fire potential.
Old 01-07-2016, 04:50 PM
Am I the only one that appreciates this genius comment?
Old 01-07-2016, 06:03 PM
non-whiner
mreid's Avatar
Ancient Chinese proverb:
Only in air cooled Porsche does the wire become the fuse, the fuse become the fire, and the fire become the car.
"Too much is just enough."
Old 01-07-2016, 07:26 PM
When this happend to me it was the left footwell blower that smoked and I was lucky it did not go further, it was a mess when I took it out to inspect.
crude rudy
'84 cab
'14 ZX-14R
Old 01-07-2016, 08:15 PM
Platinum Member
dad911's Avatar
I would leave the battery disconnected until I could inspect & repair the wiring. Where there is smoke, there is burned insulation, and likely melted insulation in other circuits.
Old 01-08-2016, 06:48 AM
My 930 used to spew smoke through my cabin vents at random times. Had the unmistakable smell of burnt electrical wiring. Really scary. I spent countless hrs looking but never found the problem. Finally, I pulled the after market alarm, stereo and all the associated wires. The wires alone filled a 5 gal. bucket. Problem solved.
It sounds like your issue is isolated to the cig. lighter but, perhaps this info will help someone else. As noted above, these cars were not wired very well from the factory. Not as bad as Jags or other Lucas wired Brit cars but poor nevertheless. Adding more electrical components to these old girls is like throwing fuel on a fire.
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 01-08-2016, 10:34 AM
ROW '78 911 Targa
timmy2's Avatar
ive just repaired 2 dash harnesses in the last month or so that had melted circuits in the clock/interior lighting as well as the lighter/fog lamp/blower motor circuits.
Those circuits are paralled up together all over the place.
On an '88 turbo harness there was even damage that was in the brake circuit.
Once there is some melting and two or more circuits get involved the damage spreads all over.
Sent from a lounge chair by the pool in Maui!
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 01-08-2016, 10:47 AM
nineball's Avatar
similar thing happened to me a few years back. turn on the ignition and the inside of the car looked like a night club - so much smoke you couldn't see. in my case the casing on the ashtray light was so old and brittle it had fallen off in parts and a lot more ended up being burnt off due to the short. i removed the wire and light bulb/socket and all was right in the world again. i personally have no use for a light in my ashtray.
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 01-08-2016, 10:56 AM
Congrats on Maui, Dennis!
Wondering about how bad my situation is. Car seems to be running fine now without smoke or incident. I'm going to run my borescope around back there and see what I can see. Will post photos.
Jason - Austin, TX
92 968 coupe
Old 01-08-2016, 12:32 PM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
Been there done that. My problem was the interior light wire within the harness, wrong relay in the power window circuit smoked the wire from one end to the other. Had to open the harness, not fun. 86 Targa 911 (Gerry) provided me with a wealth of info and now I am fused up anywhere where it wasn't. Like someone else said, fuses weren't one of their better points. The good news is you can make it right, it just takes awhile. Oh, and I too had a real hack job of a security system in there, where do they get those guys? Good luck
1986 Targa Guards Red
2021 MT09 SP
Old 01-08-2016, 04:40 PM
Actually I disagree with the critics on Bosch wiring. I find it very logical and efficient, once you understand it, especially when you wrap your head around the "current flow" diagram instead of the point to point wiring diagram.
Lucas / British - well that's pure voodoo....not even in the same galaxy as the rest of the universe...
-C
1972 914/4 Race Car
Old 01-08-2016, 07:48 PM
Borescope was inconclusive, I'll need to tear into it if I really want to see what was damaged.
I tested the fog lights; they still work. The rear defroster switch is odd - it lights up with the key on, but goes off when the engine is started - is that normal?
Jason - Austin, TX
92 968 coupe
Old 01-09-2016, 10:02 AM
DRACO A5OG's Avatar
Nope, not normal. Better yet put a volt meter on the defrost strips to insure you are getting voltage there engine off and on.
'85 Carrera Targa
PCA/POC
Old 01-09-2016, 12:07 PM
