3.2 Carrera: lean @ 2500rpm
I have a 1985 Euro 3.2 with 231 hp.
In summer it runs good but a little bumpy @ 2.5 k rpm. At cold temperatures it is nearly impossible to drive in this rpm range. It is very lean. I already changed the temperature sensor (twice), compared and messured everything but it just donīt worke the way it should. Any ideas what more I can do, or what I might have forgotten to check?
Many thanks,
Malte
Old 01-28-2017, 05:04 AM
prschmn's Avatar
How do you know it's lean? Could try closing the bypass on the AFM to see.
3.2 AFMs are kinda notorious for being problematic.
Mark
www.exotechpower.com
1981 Targa-messed with. 91 C2 supercharged track rat
Radical Prosport-irritates the GT3 guys
40 years of rebuilding services
Old 01-28-2017, 05:50 AM
kuehl's Avatar
Wide Band 02 AFR Meter: buy, borrow a wide band 02 meter to verify AFR
Vacuum leaks: spaces enlarge when cold. Try spraying carb cleaner or starter fluid (be careful) around intakes flanges at heads, vacuum lines around back of motor, oil fill cap, etc, to see if condition improves.
AFM: Testing the AFM's Potentiometer
Other: fuel delivery; filter, injectors, FPR
And, DME Test Plan
Mark, nice engine work, don't know how you squeezed those 3.8's in there.
Kuehl
1987 911 cab, modified
https://griffiths.com/
Old 01-28-2017, 06:40 AM
I checked the mixture with an CO reader. I check for vaccum leaks,too. But I did when it was warmer outside so I should give it another try.
Old 01-28-2017, 08:00 AM
It might be a good idea to clean your injectors:
https://www.youtube.com/watch?v=7aT4S1lIBAY
Old 01-30-2017, 07:55 PM
ASE Master Tech - 35 yrs
larrym's Avatar
fwiw - have a similar (maybe ) problem with my new SW chip - it pings on light throttle tip-in - Steve says it is likely lean at steady throttle & the AFM wiper is a possible cause - i have not yet taken it apart to look/test
(i am NOT running an 02 sensor - also possible problem per Steve, tho that should make it go rich, not lean imho)
"... I am German, and if it has no logic it's meaningless."
914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y
911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Old 02-03-2017, 08:51 PM
Functionista
manbridge 74's Avatar
Does the AFM look like it was previously opened?
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 02-03-2017, 08:59 PM
