86 ssinit's Avatar
Taking apart a blown engine and have some questions.(open at your own risk scary pics
In 2014 this engine blew up. been sitting for a year now and i now have time to take it apart.
I know most of this engine is shot but I'm wondering what i can salvage. can the chain tensioners be used in the 83sc.
I've removed the cylinder heads 1 was destroyed 2 have damage is this damage fixable?
as seen case is shot and i haven't split it yet.
thanks for any info.
1986 Porsche 911 Targa
1983 911 sc
2015 WRX
Old 01-16-2016, 09:19 AM
86 ssinit's Avatar
yes i know that first cylinder can't be fixed I'm asking about the 2 in the second picture thanks again
1983 911 sc
2015 WRX
Old 01-16-2016, 09:22 AM
RETIRED
Joe Bob's Avatar
Take everything apart....it's a good experience. Take all the heads, rods, pistons and crank to a GOOD machine shop. Have them check measure and estimate repairs. Junk the junk and look for replacements as needed.
Oil pump is likely junk as is oil cooler. Save all the nuts and bolts.
Use the case as a door stop.....
2012 ML350 3.0 Turbo Diesel
Old 01-16-2016, 09:33 AM
Save all the studs that you can remove from the case. Waste not, want not.
206 637 4071
Old 01-16-2016, 10:54 AM
SoyRacer's Avatar
It's really just hardware that's worth salvaging. Anything lubricated has been exposed to metal particles and is compromised. Cam gears can be saved. Pistons are risky without ultrasonic cleaning, heads would need ultrasonic and guides. The oil pump might be salvageable but would need to be gone through professionally. Remaining cylinders are good candidates for bore and replate. I window the cylinders in those areas anyway when boat-tailing a block.
Good luck and let me know if you want to sell the wasted case.
1973 Porsche 911 RS
1981 Porsche 931 Euro-Intercooled-GT
1984 Porsche 911 Euro Carrera widebody
1987 Porsche 924s Rallye Spec
Instagram: @soyracer
Old 01-16-2016, 02:00 PM
are they 3.2 heads? want to sell them as cores?
i had similar carnage when mine let go last year.. oiling problem at high speed coming onto the back straight at road atlanta big boom!
the engine surgery is fun, because its more like a post mortem dissection.... you get to see how it works and patient never has to wake up!! BINGO!
be careful removing the rings if they break they are extremely sharp!
good luck and condolences on your loss.
Old 01-16-2016, 06:30 PM
Straight shooter
Lapkritis's Avatar
Loose rod bolts?
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 01-16-2016, 06:41 PM
cycling has-been
bkreigsr's Avatar
Originally Posted by Geneman View Post
...man after my own heart. Press on regardless.
Bill K
Old 01-17-2016, 06:35 AM
Nasty.
'90C4
Old 01-17-2016, 07:01 AM
Details? Stock rod bolts and missed shift?
Old 01-17-2016, 07:34 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Wow, we really do Bleed for our cars. I have so many battle scars, it's not funny. At least the digits are still attached
Man, really sorry to see these pics, damn.
+1 a good experience!
'85 Carrera Targa
PCA/POC
Old 01-17-2016, 10:08 AM
86 ssinit's Avatar
Yes stock rod bolts. Was shifting from 2nd to 3rd at around 3500rpm. Wasn't a missed shift cause my car won't shift from 2nd to 1st without coming to a stop. Engine was running fine and had around 107k on it and was never opened. I think the rod bolt broke or the nut came loose. Haven't found those peices yet. Maybe inside the case.
Still wondering
Can I use the oil fed chain tensioners and the timing chain covers on an 83sc
1983 911 sc
2015 WRX
Old 01-17-2016, 10:54 AM
Yes they fit an SC.
Bruce
Old 01-17-2016, 11:03 AM
86 ssinit's Avatar
Ok I split the case and found the rest of the debris inside the case. I believe it was the head of the bolt on the connecting rod that caused the blow up.
Also after taking all the rods out I noticed that the blown up rod is different from all the others. Notice the numbers in the next picture. Saw in Geneman engine pic that his connecting rod is the same as my broker one. Why would I have different rods in there???? [img]http://forums.pelicanparts.com/uploads24/image1455831468.jpg[/
Again thanks for any info. Was fun taking apart the engine and I still have to take apart the cam housing.
1983 911 sc
2015 WRX
Old 02-18-2016, 01:40 PM
patz's Avatar
Budget rebuild is my guess.
Old 02-18-2016, 01:44 PM
86 ssinit's Avatar
1983 911 sc
2015 WRX
Old 02-18-2016, 01:50 PM
French Import
zippy_gg's Avatar
Motormeister?
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 02-18-2016, 01:56 PM
DRACO A5OG's Avatar
Either way, Imbecile Moron. I get sick when I see the pics :-(
'85 Carrera Targa
PCA/POC
Old 02-18-2016, 01:59 PM
patz's Avatar
Weigh the rods, check bearings, mike the the rod journal. See if the specs are out of kilter.
The replacement could have been boogie rigged. I hope your crank is OK.
Old 02-18-2016, 02:00 PM
86 ssinit's Avatar
Yes patz I'm thinking the same thing. Unfortunately for me I was told it was all original never opened. Through records and car fax I'm the 3rd owner and the second only had it for 6 months and under 1k miles. I bought the car for the same price he paid so I don't think he did the engine work. I have records from the first owner going back to the early 90s. Nothing about engine work. I guess you never know.
1983 911 sc
2015 WRX
Old 02-18-2016, 02:17 PM
