| '78 911 Coupe |
				Clutch Spring Install Tip
			Can't remember where I found this tip so I thought I would re-post. Installing the clutch spring requires the strength of Superman. Tip~ 1. Put the spring in a vice. 2. Flex the spring and push in washers between each coil 3. Slip the spring on! 4. Depress the pedal and the washers fall out. 5. Easypeasy : )   | ||
|  01-23-2016, 12:21 PM |
| Registered |
			I like!
|  01-24-2016, 08:09 AM |
| Registered Join Date: May 2010 Location: Venice, FL
			Great idea.
|  02-10-2016, 11:54 AM |
| Registered Join Date: Feb 2009 Location: Park Hills, KY
			good tip, will be rebuilding my pedal assem.
				__________________ Bob Cox 78 930 clone project car. 87 924S resurrect at some point. 84 928S, Ruby Red linen/brown interior - sold  86 944 turbo my new DE/track car - sold   | ||
|  02-11-2016, 05:34 AM |
| Registered Join Date: Nov 2007 Location: portland, oregon
			Very good way to get it done quickly and safely than pulling it with a plier at your own risk if it fails and knock out your teeth!
|  02-25-2018, 11:50 AM |
| Registered |
			great tip..I usually use regular 13mm head  nuts....same difference.. it take 2 nuts or this on picture.. Ivan
				__________________ 1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. | ||
|  02-25-2018, 11:56 AM |
| Tags |
| clutch arm spring , clutch pedal , springs |
