Ac compressor in an SC Targa
Hello... Any advice on pros vs cons of removing the AC compressor from the engine bay? ( more horsepower? Lighter weight?).
I had the car for 20+ years, and never bothered to fix the AC system, since I almost always drive the car with the targa top off.Thanx |
Topless crazy
If its not fixed then rip it out and use it as a boat anchor. Even if it was fixed, still not worth it, and still an anchor! While yer at it, rip out all the old hose, clips, dryer, condensers blah blah blah, you'll be a happier man
not to mention about 70 lbs lighter
Thank you, I am not very talented in the engine mechanics : any holes needs to be plugged? Open conduits need to be capped? Any value to the "boat anchor "? |
There is some value to the boat achor
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Vintage Owner
Though I hate the added complication of the AC system, it does certainly make the car more comfortable on those hot and humid days when you need to keep the top on.
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
Topless crazy
SDD: Not very difficult to take out the compressor. More of a pain. If you ever want to upgrade the AC you'll have to upgrade the barrier hose anyway so you can take that out too. Way easier to cut the hoses and yank them through etc. If you remove the condenser upfront, you'll have to plug the hole going into the frunk. There'll be small holes where you take off the clips underneath the car. (that held the hoses) you'll want to plug those too.
Gobs upon gobs of AC REMOVAL threads, it'll keep you reading all day. good luck |
The same old argument, rip it our or keep it.
If you live in the cooler parts of the country and almost never use AC and your system does not work at all anyway take out the compressor. I would suggest you keep every part in a box for the next owner. You will devalue the car's resale if you rip it out. If you use AC in your daily driver, think about fixing the AC. I can't even imagine NOT having AC in my situation. I drive my car and I use the AC all the time. My wife would never ride with me again in the summer time. It all comes down to how you use your car. It is your car, do what you makes you happy.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
If you remove your AC system, be sure to cap all of the fittings to the compressor, condensers, evaporator, etc. Dirt or dust in the components makes a lot of work for anyone wanting to use these parts in the future, and capping everything off probably adds to their value if you wish to sell them.
1990 964 Coupe 1986 Carrera 3.2 Targa |
Taking it out will save you about 18lbs. If the belt is off the compressor no HP gain. If the belt is on the compressor and the compressor is not turned on, fraction of 1 HP. To keep you happy, for now, take it off, put it in a box and save it. Duct tape the hose ends in the engine compartment. Leave the other AC components in the car. You can ponder them another day.
Kuehl 1987 911 cab, modified https://griffiths.com/ |
Thank you all for the input, I have kept this car all original ( only replaced the engine lid since I love that tail, came from a 76 or 78 ). So since the gain in horsepower is negligible, and I am not racing the car regularly; will keep things as factory original.
Take the compressor and condenser out. You can always out them back or include with sale. I removed mine and sealed the hoses. I did not remove the hoses. Too lazy.
82 911 SC |
Another alternative
I replaced my compressor with a Sanden, put in new barrier hoses and a new drier and it works pretty good. Makes the passenger a lot happier too! It is not that complicated, but figure all day under and around the car to replace the hoses. The cost is under $1k and it adds to the utility and value of the car. Fwiw, I have a Carrera 3.2, not an SC, so maybe the additional dash vents make it more effective.
'87 Carrera Targa '03 Boxster (sold) '73 914 2.0 (sold) |
at a minimum, if your ac doesn't work, remove the belt to the compressor (you can simply cut it off) -- this will make it a lot easier to change your alternator/fan belt should it break.
I already promised the car to my kid, especially since the odometer cable snapped at 109k in 1997, and I never bothered to fix it since I knew this was going to be a family heirloom, good luck to you son ( not really since my buddy who only works and races the sc line, said the first 100k is the "break in" period). Sent from my iPhone using Tapatalk |
Member 911 Anonymous
OT, Nice Tail
![]() BTW, I have a working and cooling AC in my Targa. Today was unusually hot day, it came in quite handy.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
