Engine number decode
I have searched a few resources to try to decode this motor serial number, but no luck. I would greatly appreciate if someone could point me in the right direction. The number is "6106197".
Thank you in advance,
Matt
Old 01-27-2016, 03:32 PM
gearhead
Should be a 1970 911T. Is there also a type number? That would tell you for sure.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 01-27-2016, 03:49 PM
Porsche 911 C- und D-Modell 1970/71
Here is a link!
Old 01-27-2016, 03:53 PM
Thanks guys I really appreciate the quick responses! Matt, what do you mean by "type number"?
Old 01-27-2016, 04:26 PM
RETIRED
Joe Bob's Avatar
A 3 digit number then a / and a 2 digit number, lighter stamping on the side rib to the right of the pulley.
2012 ML350 3.0 Turbo Diesel
Old 01-27-2016, 04:59 PM
RETIRED
Joe Bob's Avatar
Old 01-27-2016, 05:00 PM
Check the link posted by Jeffs914s, it's in German but you can figure it out. 3rd chart down, look at the "motor" column and you'll see numbers like 911/07--those are the engine type numbers which are found stamped on the engine case, on the flat, to the right of the engine number you posted.
From your number, the engine looks to be for a US sportomatic, but the type number will confirm that if it is 911/08.
Edit: use Joebob's picture to locate the type number.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 01-27-2016, 05:03 PM
Thanks again guys, much appreciated.
Old 01-27-2016, 05:59 PM
