mb911, is there any news on your build results?
2000 Boxster S 2004 330ci convertible 1978 450 SLC 1924 Model T Ford touring Fleet of Ford Buses, Sedans, SUVs and Limos |
as far as what?? Mine works(overboosted and caused damage but works and will again) Jbrinkly is running his darkmoon is running his and Damn can't remember what phils screen name is but his is going on this week.. I mostly have just been getting parts out to folks making kits them selves and this is fine to. I am the guy for the hard to source stuff..
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
Sounds good, Ben,
Can you refer me to a site that sells the urethane or rubber connectors for my intake pipes? One of these was missing when I bought my kit and I must be searching for the wrong part name because I haven't found one yet. Chris
kind of SOL on those. I was going to have them made and had good quotes but no body stepped forward to put a deposit on them so I can the project(I don't need 25 of each boot sitting on the shelf).. Maybe aluminum is the answer?? It is not totatlly dead but I need to have about 10 people put in firm deposits to do this
Unregistered
When you say damaged by overboost, how much pressure are we talking?
what ever default is of my waste gate
Brando
What does that mean? you have a hole in the diaphram? Or your margin for error is too close to the limits of the compression?
Turbo powa! 1977 911s. it's cool |
I was using a .4 bar spring and the hose going to actuate the diaphram melted and with no guage I did not realize what my AFR's were
Brando
Ouch
![]() 914 6 Turbo twinplug 3.12 87 924S Lexus SC400 Lexus LS400 |
Finally installed my MSD box last night. This model 6AL will retard my timing if I ever figure out where to attach the pressure hose to a vacuum outlet on the intake.
Does anyone have pics of how they routed their "vacuum" lines and pressure line to an MSD box?
I hooked it up to the throttle body. There should be an extra fitting back where the dizzy vac advance lines hooks up
Thanks.
Does everyone here agree that I should not have to enrich my mixture if I only run 3-5 lbs of boost? My MSD will retard the timing. Also, can anyone recommend an exhasut gas temp gauge I can use to warn me if the system ever goes lean?
Laugh
Will the MSD 6AL retard thetiming per boost? I thought this was only done using a MSD BTM6 This should help at higher boost levels to avoid detonation |
Yes. The 6AL I have includes the ability to retard at 1 lb, 2 lbs, and 3 lbs of boost. There is also a dial controller I can put on my dash. I believe the 3 settings on the knob will retard timing further, but am not sure yet.
The next step in my current plan is to get an exhaust temp guage to monitor mixure before installation. Do you want the part number, etc off the MSD box?
I actually installed a MSD BTM this weekend for the same purposes of turbo charging. I plan on doing the turbo in the next 2 months but am also curious on how much boost I can run safely.
Pics from my weekend install ![]() |
Unregistered
If you are running CIS it will make allowances for up to 5 psi boost with no problem, unless it is running lean already.
I ran mine at 7 psi with no ignition retard for a couple of years, all I did was richen it up a bit. At 5 psi you should be fine, providing you are running premium. |
I thought it's time i check in and resurrect this thread. I have been away for awhile and have been busy working on my car, it has transformed overtime and all of the things i tested and fabricated using Thad's outline have finally culminated into this. It may be a 914 but it's heart was originally a 79SC engine all of the modifications would apply to the 911's.
Learn more here: http://www.914world.com/bbs2/index.php?showtopic=75381 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
![]() 914 6 Turbo twinplug 3.12 87 924S Lexus SC400 Lexus LS400 Last edited by iamchappy; 12-14-2007 at 07:02 PM.. |
Looking great. We appreciate the updates. Do you have any plans of dyno tuning her? My memory fails......which tranny you running?
Luke S. 72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT |
