replacing hood struts
easy question, replacing hood struts that were previously removed on a 71 T, does the rod/gas tube part attach to the bottom or top.?
Old 03-12-2016, 05:11 AM
MBAtarga's Avatar
Pelican Technical Article: 911 Hood Strut Replacement
Mark
'83 SC Targa - since 5/5/2001
Old 03-12-2016, 06:28 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Rod = bottom, toward chassis.
'85 Carrera Targa
PCA/POC
Old 03-12-2016, 06:55 AM
RETIRED
Joe Bob's Avatar
driver clip, doesn't have to go in, just the pin......that is all
2012 ML350 3.0 Turbo Diesel
Old 03-12-2016, 07:40 AM
As I remember, the driver's side strut is a mother.
Tom
Old 03-12-2016, 08:27 AM
Although more expensive, I found this aftermarket strut much easier to install, and longer lasting, than the factory gas struts.
1986 Porsche 911 Carrera Coupe - Bumpers, Doors, Latches & Lids - Page 10
Old 03-12-2016, 11:54 AM
Recreational User
porschenut's Avatar
The clip goes over the end of the pin with no difficulty whatsoever, on either side. Just hold the clip with needlenose pliers and it goes on slicker than snot on a doorknob. Done it many times.
Old 03-12-2016, 12:57 PM
Recreational User
porschenut's Avatar
That Ultimate Strut that was linked to earlier isn't worth 10 cents. Sooner or later you'll forget it's there and you'll bend it when you try to close the lid. That will cause the fiberglass pole to fracture, sending glass shards everywhere, including right through the intake grill below the windshield, destroying it. Ask me how I know. That's right, that piece of glass rod will hit it with such force that it will tear a 1" hole in the metal grill.
Old 03-12-2016, 12:59 PM
got em all in (2 front and 1 rear) with all clips in about 20 mins, no biggie. Looks like I'm getting a little push up in rear of the hood and will have to adjust down a tad
Old 03-12-2016, 03:09 PM
DRACO A5OG's Avatar
Remember there are two holes on the chassis in the rear. Make sure it is in the correct one.
'85 Carrera Targa
PCA/POC
Old 03-12-2016, 04:45 PM
I think I saw only one available pinhole (top and bottom) for the front hood struts (71), but I'll look again. Thx
Old 03-13-2016, 05:43 AM
