disassemble fan too here....
So I'm taking apart my fan to powdercoat it.. I've gotten to here.. what's next. Seems stuck.
Old 02-17-2016, 03:22 PM
al lkosmal's Avatar
There at least a couple of ways to do this.
1. You can tap a couple of the small holes adjacent to the fan pulley half. Then use a couple of bolts, and slowly thread them in, alternating from side to side. to drive the fan off.
2. Use a 3 legged gear puller....wrap tape or some other soft stuff around the puller feet to ensure no damage to the fan occurs.
These both work well and there are probably other ways..........we'll see who chimes in.
RGruppe #669
http://www.x-faktory.com/
Old 02-17-2016, 03:41 PM
Use 2 or 3 blocks of wood to support the fan housing, so that the alternator hangs down but doesn't contact the table. Then lift it up a few inches and drop it onto the blocks. 2 or 3 times and the alternator will drop right out.
1986 3.2 to 3.4 conversion
Old 02-17-2016, 04:15 PM
Member 911 Anonymous
DRACO A5OG's Avatar
on towels :-), key is the housing my be parallel to the ground, gravity is at work here :-)
'85 Carrera Targa
PCA/POC
Old 02-17-2016, 05:02 PM
without undoing anything else? (aside from those 3 bolts?)
Old 02-17-2016, 05:06 PM
Functionista
manbridge 74's Avatar
Been using the block method for years. You can use some penetrant as well.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 02-17-2016, 05:12 PM
DRACO A5OG's Avatar
^^^ +1
'85 Carrera Targa
PCA/POC
Old 02-17-2016, 05:14 PM
ok. ill try it. so fan facing down (second pic, where wires go..up). and lift and drop?
Old 02-17-2016, 05:15 PM
I just did the wood block method and it worked like a charm for me. Give it a try.
'86 Carrera
Old 02-17-2016, 05:21 PM
al lkosmal's Avatar
I get the alternator out by using the drop/block method.....but i take the fan off first....using the puller.
regards,
al
RGruppe #669
I pull the fan off first with pullers
Then I drop the AC off the blocks
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 02-17-2016, 06:07 PM
I used a bucket with rags in it to catch the alternator once the housing let it go using the 2x4's placed on the rim of the bucket.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 02-17-2016, 06:32 PM
Zaz Zaz is offline
Search "John Walker method"
74 911 Coupe
74 Triumph TR6
97 Jaguar XJ6
Old 02-17-2016, 07:23 PM
